Coilover question
Gavlar Mar 20, 2011
  1. Gavlar
    Gavlar Member
    312
    45
    Right I fitted my coilovers on the rear and they are set at the same height but one side is lower than the other and the camber is different even though they are both set the same what could the problem be?
    Also I have a rubbing noise comin from the rear now but it's not touching anywhere
    Would I be mad in sayin that u need to adjust each one differently to be the same all round?
  2. Gavlar
    Gavlar Member
    312
    45
    Anyone got any ideas?
  3. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Set the rears up and take a measurement from the ground (level ground)to the lip of the rear arch and adjust , as long as all messure the same you should be fine. Use this company for the wheel Alingment .www.AlignMyCar.co.uk as you will need all four wheels done.
  4. Gavlar
    Gavlar Member
    312
    45
    Cool thank you. Also the springs on the rear have a couple of coils touching. Is this ok?
  5. CMD
    3,015
    17
    Gavlar how low is the back
  6. Gavlar
    Gavlar Member
    312
    45
    Well one side is lower than the other and it is really low. Top of the tyres are in the arches. Tried adjustim it up but didn't really seem to do much. Think I may have to wait to see what Amd Essex say on Thursday
  7. ChrisFurlong
    ChrisFurlong Avantageous
    343
    Are these the KW Street Sports you've bought? If so, hows the ride on them? I know it may not be great with one corner lower than the rest.
  8. Gavlar
    Gavlar Member
    312
    45
    Just had a look up the near side arch and it looks like it's touching the plastic inner lining. Could this cause a rather loud noise? And it seems to go when cornering left.
  9. CMD
    3,015
    17
    Yes that will. You must be low then?
  10. Gavlar
    Gavlar Member
    312
    45
    Yeah it is plus the camber is out at the top on that side even though I have adjusted it right in. Well if this is the problem it will all be sorted on Thursday once it all fitted and aligned properly :)
  11. CMD
    3,015
    17
    Good luck with it. I have been without my car for over two weeks now as i'm having a few thing's done one of which is taking the plunge back into coilover's, the report's i have had back so far from the guy's doing the work is that the rear of the is looking nice and low, i have asked them not to adjust the coilover's as i like to do this myself. The front should be 40mm lower as i have set the hight on the front's.
  12. Gavlar
    Gavlar Member
    312
    45
    Why is it taking So long. And how do you know you have set them up to 40mm?
  13. CMD
    3,015
    17
    It's not taking long to do the suspension or anything like that it's i just have not had a chance to get up there and pick it up. The garage space they have is massive and my car is in safe hand's. The 40mm set up is easy and you could have also done it Gavla, by using components from another audi. Gavla can i ask how much you paid for your coilover kit.
  14. Gavlar
    Gavlar Member
    312
    45
    I paid £215 for fk ak street coilovers. Why's that mate.
  15. CMD
    3,015
    17
    How much was the fittig
  16. Gavlar
    Gavlar Member
    312
    45
    Well was £240 but I have fitted the rear but still goin to get the front done and set up
