Coilover fitting
smudge_don Oct 26, 2009
  1. smudge_don
    smudge_don Active Member
    2,944
    Can't seem to find a tutorial on it or anything, anyone done a step by step guide for fitting coilovers at all?
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,493
    635
    mmmmm you never done it before to any other car?
    its handy enough on the A3's, changed plenty of suspension and coilovers before.
    wheels off
    caliper off
    drop links off
    driveshaft out of brake/hub
    raise scuttle panel slightly to remove 3 off bolts at the top mount
    lift whole front suspension out with brake
    remove bolt holding shock and hammer out
    remove top mount
    use a chizel to help pry open the back of the brake to reinsert the coilover and bolt in
    get a couple of threads on the 3 top bolts at the top mount
    reinsert drive shaft
    reattach drop link
    put caliper back on
    check everything is tight
    bit vague but you will see as you go along
    the back is **** easy - jack up one side and have the other on an axle stand, remove both shocks (2 bolts at top, 1 at bottom).
    the rear beam will drop so insert coilover springs
    attach new shocks to the top first then use the jack to raise the rear beam up to the bottom of the shock to make it easier to bolt in.
    check everything again for tightness
    wheels on, go drive to get for noises.
    if in doubt, seek help
  3. smudge_don
    2,944
    I've never done the fronts before, backs are always **** easy!
    Cheers Boydie, might even do a tutorial with pics myself when i do it for others :)
    'coz im nice :scared2:
  4. Boydie
    3,493
    635
    Good lad - just take it easy and watch that the drive shaft doesnt come out of the engine block lol shouldnt do but just take it easy. Watch for the brake clips and sensors etc...
  5. boggysv
    boggysv Member
    573
  6. smudge_don
    2,944
  7. N8
    17,163
    720
    You text me that monday mornin, get a move on lad! :asskicking:
  8. smudge_don
    2,944
    Well i'm not having to do it with a friend that has axle stands, rather than a friend that has a fcuking ramp and lift!
    Would be much easier with that but he's been a bitch all week
    So hush!
  9. N8
    17,163
    720
    Get pics up when its done, whens your wheels ready?
