coil spring question?
finesse Oct 26, 2010
  1. finesse
    finesse Active Member
    2,805
    Couple of questions regarding the replacement of my front coil springs.
    Audi want 78.81 each for a coil spring, the same price as a set of aftermarket lowering springs.
    If I go for lowering springs, what brands are recommended? H&R, Eibach, Wietec, KW or AP? A pair from GSF or ECP?
    If lowering springs are fitted,
    would wheel alignment be required?
    How is the ride and handling affected?
    how many hours labour to fit a set of lowering springs?
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Hi buddy.
    First comment is with lowering springs, your standard dampers could be affected. I say could, because it depends on the height you lower to.
    I can't comment on the handling side of things, but was quoted £150 all in to fit from Awesome GTI and that included a tracking setup at 56 quid. Think it was plus vat though.
    Re the tracking, yes. You've lowered the vehicle, so even if the tracking isn't out, the camber is likely to be, so could cause uneven tyre wear.
    I'd do a search for JoJo's comparison of H&R and Eibach springs. Great write up, although he has uprated dampers as well...
  3. JD09
    3,096
    46
    P.s there are a few springs and dampers on eBay at the moment buddy... Cheaper than Audi. Depends, do you want a quick fix for now, or are you wanting to replace the lot?
  4. finesse
    2,805
    quick fix, cheapest way naturally.
    I have Koni FSD dampers l, I heard Eibach are very good.
    would be a good combination but the extra work required ......:(
  5. JD09
    3,096
    46
    Ah, well if you have uprated dampers, get uprated springs :) Read JoJo's thread buddy :)
  6. Ian W
    Ian W Active Member
    1,058
    12
    Don't forget if you lower it you will need adjustable rear tie bars to get the back end straightend out.
    This bumps the price up quite a bit !
  7. finesse
    2,805
    thanks jd
  8. finesse
    2,805
    thanks Ian, springs from Audi now sound appealing
  9. JD09
    3,096
    46
    That was my thinking bud. Standard springs meant standard tie bars. Uprated stuff meant new springs, new shocks, new tie bars and a tracking setup... Which all in one go = ££££.
    Although I have now got to £400 with just the rear OEM stuff going on :( My advice, if you just need a spring as a fix, get a cheapo one. I might even have some going soon, as going for brand new OEM or another option from a kind member on here...
    When my front one broke, I was not in a position to justify replacing anything other than just one standard spring. H'actually got a bargain off another kind member, i.e. just paid postage, so that's another thought line to go down!
  10. scoobyra
    scoobyra It's not f@cking ORANGE!!!!!
    798
    I've just put som H&R's on my standard suspension and it's made it less bouncy but more bangy (is that a word?? LOL). TBH the front has come down quite a bit but the rear is still quite high and there's no noticeable difference in the camber.
  11. JD09
    3,096
    46
    It's a word, but can only be used in certain upstairs rooms :thumbsup:
  12. finesse
    2,805
    jd sell me your springs :)
  13. JD09
    3,096
    46
    Haha, OK!
  14. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,824
    107
    I have some standard springs in my unit
  15. finesse
    2,805
    Paul, what you mean?
  16. S3 Paul
    2,824
    107
    I have the stock springs from my car in my unit...
    Like my mates keep saying "well you aint ever going to go back to standard are you "?
  17. jojo
    28,856
    3,516
