Coil pack upgrade?
rustynlc Jul 20, 2014
  1. rustynlc
    rustynlc Member
    186
    20
    Hi folks, any idea what the best upgrade for coil packs? My motor is a 1.8t AJQ (180bhp) iv got a mate who has a knackered 3.0 v6 ASN engine any reason why them coil packs wouldn't fit on mine? Plug looks the same, just they have red tops instead of black, cheers for any advice and tips folks
  2. Nilz
    11,320
    872
    You can fit the 2.0 tfsi coils to your car.
  3. Greg-S3
    Greg-S3 Active Member
    540
    53
    I fitted the 2.0 tfsi ones as suggested above! Look cool!
  4. <tuffty/>
    20,903
    3,713
    There is no real 'upgrade' for coil packs... TFSI ones were once touted as being better than 20v ones (push done not bolt down) but tbh they are no better... they still fail (have seen a fair few) and they produce no more power (tested on the dyno)
    I used to run larger gaps (0.85mm rather than the normal 0.7mm) but started experiencing misfires on hi boost... closing the gaps fixed this suggesting the TFSI coil packs are just as prone to misfires as 20v ones
    Just buy brand new OE ones... they will work
    rustynlc likes this.
  5. VAG-Slag
    VAG-Slag Well-Known Member
    1,752
    400
    Tuffty, am I right in saying the TFSI ones do have a higher output?
  6. <tuffty/>
    20,903
    3,713
    Its alledged but not seen any proof...
  7. Andrew@A.L.D
    3,873
    609
    You can fit the LS1? coil packs. But they look dog ugly but as Tuffty said OEM are fine
  8. Sam_
    Sam_ Down under
    3,035
    480
    Yeah 034 do a kit using LS2 coils but plenty of high power cars run the push downs. The Hitachi bolt downs are said to last longer but again this is just what people say. At the end of the day the TFSI ones are cheap enough to replace when they eventually cark it.
  9. rustynlc
    rustynlc Member
    186
    20
    Thanks for the replies folks, so no real advantage to them then, ok I'll file these coil packs in the garage for a rainy day,
