Coil pack problems. Upgrade coil pack options ?!
aarondown91 Mar 19, 2013
  1. aarondown91
    aarondown91 Member
    31
    Car was firing on 3 cylinders suddenly so i changed the spark plugs in my s3 ran well for a day then the loss of power under load and misfiring started again which leads to coil packs playing up but no faults coming up on the ethos.
    I have the bolt down type coil packs
    I was thinking of replacing the set but don't know what's best as I heard you can fit the red coilpacks from the 2.0 tfsi I this correct and if so is there a certain year or is it all of them?
    Or there's an upgrade set on eBay for £90 but are not bolt down. Does this mean they won't sit properly or are they a different design that works without bolting down?
    cheers
  2. <tuffty/>
    21,148
    3,833
  3. mattyboy199
    mattyboy199 Well-Known Member
    1,892
    30
  4. <tuffty/>
    21,148
    3,833
  5. aarondown91
    aarondown91 Member
    31
    ok thanks for info. is the adapter for the connecting plug or for holding the coil in place. have you done this conversion?
  6. aarondown91
    aarondown91 Member
    31
    cheers for the links :) have you done this conversion?
  7. <tuffty/>
    21,148
    3,833
  8. Andrew@A.L.D
    3,877
    617
    I know some one that has some 2.0 FSTI coil packs going spare :think::salute:
  9. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    Bolt down coil packs very rarely fail.
    In fact, I don't think I have ever seen a set fail.
    Check ignition amp, as well as the wiring to the packs.
    You'll need to rewire if you want to fit TFSI packs to an ME3 car.
  10. <tuffty/>
    21,148
    3,833
    The OP has an S3 dude... bolt down with internal amps, not like the AGU... he can just swap over to TFSI packs and use the OE adaptors in the link I posted
  11. 16Klappe
    5,795
    1,184
    I'm a d**k.
    As you were...
    scotty_24 likes this.
  12. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    They actually sit fine without adapters as well by the way...but i suppose it tidies it up..
  13. mattyboy199
    1,892
    30
    tuffty from what i've read TSFI coils fitted to a bam engine is plug & play again with adapters to just smarten it right ?
    I just looked on the awesome website there is 2 sets £78 & £84, which set & whats the difference ?
  14. Gops
    3,198
    666
    Go for the one that say 06e. 07k are warned against on some yank forums. I got red ones anyhow :D
  15. <tuffty/>
    21,148
    3,833
    Any engine with the push in coil packs you can just replace easily with TFSI coils... the adaptors are purely for show in this case... on earlier DBW S3 (APY) and A3 TQS with bolt downs then again they are simply swapped out for TFSI but while the TFSI (and push down 20v packs for that matter) are held securely on the plug they will wobble about at the top as there is nothing to hold them... the only choice before was to buy the expensive alloy adaptors but now of course you can buy the cheaper OE adaptors and this will secure the packs nicely...
    Early AGU engines with ignition packs can convert to later coil packs, not sure of the process as I have never done one but its popular with the AEB A4 owners stateside...
  16. James TQ
    James TQ Member
    561
    i have the same problem iv just orderd tfsi coils and adapters from dealers but not going to need them as its the lambda sensor
  17. aarondown91
    aarondown91 Member
    31
    Just spoke to them on the phone and was told that these don't work on tha apy bolt down coil packs because the wiring plug isn't the same?!
  18. <tuffty/>
    21,148
    3,833
    Not convinced... have seen APY's running these but without a coil pack in front of me I couldn't confirm for sure but I am pretty sure they are the same plug... they do differ on the AGU though
  19. aarondown91
    aarondown91 Member
    31
  20. <tuffty/>
    21,148
    3,833
  21. mattyboy199
    1,892
    30
    Which lambda sensor has failed on your car, pre or post cat ?
  22. James TQ
    James TQ Member
    561
    vdcs says bank 1 sensor 1 im running a decat so im guessing its the one on that pipe as there is a hole for a sensor on the downpipe but its blanked off, can anyone confirm its the one on the decat pipe?
  23. <tuffty/>
    21,148
    3,833
    Bank 1 Sensor 1 is the precat probe
  24. aarondown91
    aarondown91 Member
    31
  25. James TQ
    James TQ Member
    561
    is the precat probe the one on my decat pipe as i cant see any other on the system unless theres one in the manifold there is space for one on the downpipe but its beed plugged off, am i right in saying my car only have one of the lambda sensors?
  26. mattyboy199
    1,892
    30
    James it depends what year & engine your car is, older engines have 1 & newer engines have 2.
  27. James TQ
    James TQ Member
    561
    1999 a3 quattro ajq
  28. aarondown91
    aarondown91 Member
    31
    how much did you pay for them with adaptors?
    was it for an apy engine?
  29. mattyboy199
    1,892
    30
    But which ones ?
    ECS Tuning Red Ignition Coil Pack Set 1.8T 150/180/210/225 - S3 (8L) - Audi - Shop By Car
    ECS Tuning Red Ignition Coil Pack Set 2.0TFSI - S3 (8L) - Audi - Shop By Car
  30. James TQ
    James TQ Member
    561
    ajq code packs were £77 adapters £1.20 each plus vat from dealers
  31. <tuffty/>
    21,148
    3,833
  32. Sneekyparrot
    Sneekyparrot Member
    45
    New or used?
    Need a set to convert my BAM Motor.
    cheers
    Paul
