coil pack failure now engine management light on
deac666 Jan 19, 2014
  1. deac666
    deac666 Member
    45
    Hi all, had my engine rebuilt not to long ago. problem now is I had a coil pack go down today and engine management light came on.
    so I changed the coil pack but the engine management light is still on. could this be because of the coil pack failure and it just needs reseting to turn the light off.
    Any help would be great cant get to a garage as all local ones are closed tomorrow and have to do a long run Monday.
    thanks in advance cheers jon
  2. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    It maybe as its still in the memory, does the car run as normal now?
  3. deac666
    deac666 Member
    45
    Thanks for the reply. yea the car is running as normal. the light started flashing then went on constant. so I changed the coil pack and the light remained on.
    cheers jon
  4. Nilz
    11,367
    908
    Well see if you can get it scanned and see how you get on once all fault codes have been cleared, it should be ok then.
