Coil Overs
Alex C Feb 14, 2010
  1. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,305
    375
    Hi guys
    I have read the suspension set up sticky where I get the idea that coilovers are different to normal shocks? I'm not saying they aren't, but how are they different. I thought a ccoilover was just a normal shock with the spring over it, like the S3 has on the front as standard.
    Whats so special about coilovers
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Coilovers are fully adjustable where as shocks/springs are a at a set height.
  3. jojo
    29,001
    3,657
    I think it's more accurate to say coilovers are usually height adjustable, but you can get ones which are adjustable for damping(usually more expensive), and you can get springs and shocks which have adjustable damping only with fixed rate springs.
  4. Alex C
    3,305
    375
    Thanks Weslte, so thats the only difference, they look and work the same
  5. Alex C
    3,305
    375
    how do you change the spring rate on a coil over?
  6. Alex C
    3,305
    375
    oh, does changing the dampening change the spring rate
  7. jojo
    29,001
    3,657
    By changing the springs itself.
  8. jojo
    29,001
    3,657
    Nope, damping and spring rates are 2 different things.
  9. Alex C
    3,305
    375
    ok, so you cant change the spring rate on coilovers or normal shocks without changing the springs
    and you cant change the ride height on normal shocks
  10. Westy
    17,443
    1,105
    Pretty much spot on. :)
  11. Alex C
    3,305
    375
    thanks again
  12. jojo
    29,001
    3,657
    That's pretty much correct. You base the spring rates on the weight of the car, and the damping rates you either have fixed or adjustable, depending on what type of setup you want. Coilovers usually have firmer damping rates than normal/uprated shocks, as most people tend to run them on a low setting, so the firmer damping rates stops the car from bottoming out.
