Coding Symphony II+
AlexGSi2000 May 9, 2012
  1. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Just after some advice on this as I have never used vag-com to code / make adjustments before - only ever used it to scan for fault codes.
    Basically I am upgrading the factory audio in my 2002 A4 from a Symphony II, to a Symphony II+
    I have found the following on the net;
    Audi Radio Generation II Plus - Ross-Tech Wiki
    The new unit is from America, so I need to change the country to Europe.
    The car is a 2002 A4 Avant TDi with material interior, so im guessing I will need to change to; wagon/avant and diesel engine.
    My issue is, I dont know what 0xx0xx? means, or how to get there and how to change it.
    Im taking it I go to the "radio" section of vag-com, go to adaptation - from there im lost!... Any help would be appreciated.
    Thanks.
  2. JST_A3
    JST_A3 Member
    99
    Alex,
    Use the Coding button within VCDS to change the configuration. Once there you should get a help message to explain the different options that are available, but based on what you have said I would suggest a coding of 0??0221, this consists of the following:
    0 - Fixed, no options
    ? - Add the digits together depending upon what is fitted. If you have MFSW use 2, if MFSW & Telephone use 6 (2+4)
    ? - As above. If you have a CD changer use 2, if CD & Digital Sound use 3 (2+1)
    2 - Diesel engine
    2 - Avant
    1 - Europe
    I'm not familiar with the A4 radios so assume that they both work on CAN-bus, if not then you may need to make other changes to the CAN controller module to enable the radio to be identified.
    Hope this helps.
    Steve
  3. AlexGSi2000
    1,464
    199
    Many thanks for your help - I think I understand how coding works now!
    The Symphony II+ will be retrofitted into a 2002 A4 without CANBUS using a quadlock to ISO convertor.
  4. AlexGSi2000
    1,464
    199
    Just an update on this - the unit arrived from America, I managed to code everything apart from the region setting.
    Whenever I tried to code to Europe it came up with an error.
    Not sure if there is any way around this?
