Ok so I bought an S3 during the week that has ADAPTIVE LIGHT DEFECTIVE error on the dash (circle with arrow in top right and little light rays on left). After messing around a fair bit I get this error in VCDS:
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 29538C00FCDD
Part No: NOSUBSYSTEM
Component: AFS-Modul links
Component: AFS-Modul rechts
1 Fault Found:
02071 - Local Databus
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 98
Mileage: 110088 km
Time Indication: 0
Date: 2013.09.26
Time: 08:23:54
As the car is a CAT D with frontal impact I then thought to see if the adaptive bi-xenons that should be in the car were replaced with regular bi-xenons. I checked the part number of the headlight and its:
8P0 941 004 AA
So Im pretty sure that this is the case. The lights work fine but dont move up and down with ign on. IN VCDS it wont allow me to adjust them or do any of the output tests.
So the Question is can I fix this via coding? Im happy not to have the adaptiveness (so Ill not be buying new lights) all I need is the damn flashing light off the dash! I tried pulling fuses 5&6 (for adaptive lights) but made no difference.
Appreciate any advice. Thanks guys.
Coding: 0000020
VCID: 29538C00FCDD
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 98
Mileage: 110088 km
Time Indication: 0
Date: 2013.09.26
Time: 08:23:54
8P0 941 004 AA
