coding keys with vcds?
glenandem Feb 26, 2013
  1. glenandem
    glenandem Active Member
    674
    31
    is it poss to code the actual key chip with vcds if i have the skc number?
    i know you can code the remote side but just wondered about the actual immobiisor bit?
  2. hades-
    9,481
    646
    yes if yiu have the SKC
  3. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    What's an skc and how do you get it?
  4. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    SKC is the code required to access immobiliser coding in instruments. It used to be on a small scratch off card, but after a certain year you can only get from dealer as they have to connect to Audi Germany and the code is sent to the car. The Dealer willnot be able to give you the code.
  5. Mikemc
    1,024
    37
    So it's not possible to code your own key?
  6. gen.heinz guderian
    1,346
    126
    Yes you can , if you have the code and vcds and the car is before 2005/6, After that its Main Dealer job.
  7. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,815
    194
    Sometimes the SKC is retrievable with other cables/software to VCDS, but not with VCDS itself.
  8. Mikemc
    1,024
    37
    I bet that software and cable costs a fortune?
  9. gen.heinz guderian
    1,346
    126
    NHN sells VCDS on here pm him for a price.
  10. gen.heinz guderian
    1,346
    126
    vagtacho should be able to retrieve, but not after 2005/6
  11. Mikemc
    1,024
    37
    I meant the software for pulling codes, and already spoke to him, he's awaiting delivery of stock
  12. hollow
    hollow Well-Known Member
    1,404
    162
    depends on the year of the car and what clocks you have , i can retrieve skc codes sometimes via obd other times by removing eprom from clocks and reading in a programmer
  13. glenandem
    674
    31
    is it poss to recover the skc on a 1.9tdi ecu with vagtacho,if i can get it with that then hopfully i can code the key in with vagcom!
  14. @udi A3
    1,815
    194
    I can pull my 1.9tdi pin with commander i think. i have tacho and commander though, my A6 uses tacho. I think its a bit hit and miss as im using cheepo ebay cables, but was only for that purpose and to do the miles to empty on a buddies car. VCDS genuine for everything else.
  15. craigynett
    craigynett Member
    294
    10
    even with the SKC you're not going to be able to program a new key to a 2005/6 onwards VAG because the transponder has to be pre-coded with CS (compenent security) info before it can be programmed to the car. Pre-coding equipment is expensive so definitely not worth it for somebody who wants to do 1 key to their own car.
    I've got 2 different bits of equipment that will pre-code transponders. Pre-coding is basically making a dealer key without going to the dealers
