Coding help please !!
xtremedetailz Aug 11, 2013
  1. xtremedetailz
    xtremedetailz Member
    79
    Hey guys
    Both my keys have not worked for the car for around 6 mths and they have both worked fine with new battery's etc etc.
    I have tried recoding the keys to the car following numerous different ways online and even took it to a key coding shop with no avail.
    Im having to lock my car with the key and it locks all the doors and boot and shows this by flashing the indicators with every turn but when it comes to unlocking it will only unlock the drivers door without any indicator flashes and if i dont put the key into the ignition within so long it sets the alarm off until the key is inserted into the ignition and turned on.
    Now when i do a VCDS scan it is showing an error on the Can bus saying coding error and it wont let me connect to the central locking (module 35)
    Im hoping its something as simple as that but id need help recoding to use the module.
    Here is a scan of the VCDS :
    Tuesday,06,August,2013,20:16:56:10074
    VCDS Version: Release 10.6.4 (x64)
    Data version: 20110418
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 77 7D
    Mileage: 213960km/132948miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Not registered 0001
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 1247
    Revision: --H22--- Serial number: AUX7Z0F5FNG0FF
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    VCID: 74E3D8E36E2B
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Shop #: WSC 06314 000 00000
    VCID: 73E1DBFF6B25
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
    Component: KlimavollautomatH18 0300
    Revision: 051559 Serial number: 8P0820043P
    VCID: 397D29D709C9
    1 Fault Found:
    00483 - Control Module for Auxiliary Air Heater
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 233
    Mileage: 213042 km
    Time Indication: 0
    Date: 2013.07.25
    Time: 12:37:03
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000005893012
    Coding: 01884F07A214100000000000000000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 408B44336A13
    Part No: 3C2 955 119
    Component: Wischer VW461 012 0503
    Coding: 00065493
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H12 3720
    Revision: 91H12372 Serial number: 0037W002D5X9
    Coding: 0071612
    VCID: 47995F2F4F3D
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 034 0070
    Coding: 0000012
    VCID: 78FBECD37243
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
    Component: KOMBIINSTR. VDO H16 0550
    Revision: D0H16001 Serial number: 2245F001000433
    Coding: 0004413
    Shop #: WSC 65536 773 2073257
    VCID: 3B7133DF03F5
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 30001065318B04
    Coding: 3D0F0BC207000101
    VCID: 2B51039FF395
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 213969 km
    Time Indication: 0
    Date: 2013.08.06
    Time: 20:07:57
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H16001 Serial number: AUX7Z0F5FNG0FF
    Shop #: WSC 00000 000 00000
    VCID: 3B7133DF03F5
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7LD223161
    Coding: 0205751
    Shop #: WSC 00114 211 10555
    VCID: 346318E32EAB
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000560
    VCID: 408B44336A13
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.078 H07 1806
    VCID: 356525E725D1
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 198000186D288505489AC63300
    VCID: 3C7330C306FB
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH27 0160
    Revision: 00005 Serial number: 30659630424994
    VCID: F0EB54F39A33
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000560
    VCID: 418D41376119
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205751
    VCID: 346318E32EAB
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
    Component: FSE_255x BT H21 0290
    Revision: 00000001 Serial number: 00000000480883
    Coding: 0010122
    VCID: 3B7133DF03F5
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D550D87CD81
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    End ---------------------------------------------------------------------
    Any help would much appreciated.
    Mark
  2. xtremedetailz
    79
    anyone ?
  3. Chillout
    Chillout Active Member
    609
    50
    I have not personally come across this issue but have you tried what is advised for that code on ross tech
  4. mike foster
    3,967
    Is that a genuine VCDS - current release is 11.11.3. ?
  5. Chillout
    609
    50
    i think the current one is 11.11.6
  6. mike foster
    3,967
    Sorry, my bad ! It is 11.11.6, put it down to a geriatric typo !!!!
  7. Chillout
    609
    50
    I will let you off this time! Lol
    just thought you were missing out on your free updates
  8. xtremedetailz
    79
    Yeah my friend has updated to the 11.11.3 and not had chance to come back over to mine and do another scan (yet)
    Im hoping once i have help he will come back over and help me code whatever is missing or whatever is wrong.
  9. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    check coding of 19. check plugs, check measuring blocks for communication errors. replace can module maybe. test remotes first. if your local ill pop round and have a look.
  10. craigynett
    craigynett Member
    294
    10
    with 8P A3 you don't connect to central locks, module 35. You connect to central convenience, module 46 which has shown up as status OK in your scan.
    Connect to 46 & clear the remote memory then try adapting them again. There isn't any info for 8P A3 on Ross-tech wiki so just use 8E A4 guide
  11. xtremedetailz
    79
    Tried that mate but its not showing the key once the button is being pressed.
    Once i clear it and hold the button for 1 being one key and saving when i press the button that is still in the ignition a get one flash from the indicators and nothing else..
    Really puzzeled.
  12. craigynett
    craigynett Member
    294
    10
    if you get a flash from the indicators when you press your remote then it's usually programmed. As soon as they've flashed you click save then click yes when small confirmation box appears.
    So then you'd move on to 2nd remote. Click read, type the number 2 into the relevant box, click save then press button on remote until indicators flash, click save then yes! job done
    What year is your A3?
  13. xtremedetailz
    79
    It's a 2006 mate.
    its got the newer style fobs.
  14. craigynett
    craigynett Member
    294
    10
    should be very straight forward mate. What did the key coding shop do?
  15. xtremedetailz
    79
    The key coding said I'd have to take it to Audi.
    They replaced the battery and tried to pair it up but with no joy.
  16. craigynett
    craigynett Member
    294
    10
    Hi mate, can't access my inbox so my number is 07900600548 if you need help with the remote problem, can go through it with you over the phone etc ;)
    LEE69 likes this.
  17. craigynett
    craigynett Member
    294
    10
    all sorted! very bizarre problem! both keys were sending an RF signal but wouldn't operate remote locking even when indicators flashed during programming. Tried both my remotes & they worked straight away after programming
    LEE69 likes this.
