Coding errors after Retrofit RNS-E, BT Phone and MFSW- Please help
dme Mar 2, 2012
  1. dme
    dme New Member
    Good afternoon all,
    I love this forum, I have been reading for weeks. I have recently retrofitted RNS-E, AUDI BT Phone wired for SDS and MFSW. I have most of it working but have a few errors I would like to discuss with the knowledgeable, helpful folks on here. I have the BT phone volume problem that appears to be well documented; however I have a few errors I would like to get sorted first.
    I have a 2006 A3 Sportsback 2.0 TDI DSG. I have a mate who has a genuine RT VCDS, here are the logs with errors. Any help would be massively appreciated.
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 77
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
    Component: R4 2,0L EDC G000AG 9558
    Revision: --H06--- Serial number: AUX7Z0G0FN80RO
    Coding: 0000078
    Shop #: WSC 06314 000 00000
    VCID: 6FE9D78F070D
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 043 M HW: 02E 927 770 AE
    Component: GSG DSG 070 1301
    Revision: 00007000 Serial number: 00000612091104
    Coding: 0000020
    VCID: 1E37DA4BB027
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    VCID: 73E1DBFF6B25
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
    Component: KlimavollautomatH19 0360
    Revision: 087601 Serial number: 8P0820043AC
    VCID: 6DD5CD870D01
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000006533180
    Coding: E4885F21B014100000160000160000000008FA175C0100
    Shop #: WSC 06314 000 08192
    VCID: 408B44336A13
    Part No: 8P2 955 119 E
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150573
    Shop #: WSC 06314
    1 Fault Found:
    00526 - Brake Light Switch-F
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 105298 km
    Time Indication: 0
    Date: 2012.02.24
    Time: 15:21:00
    Freeze Frame:
    ON
    Voltage: 12.10 V
    ON
    ON
    OFF
    OFF
    ON
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H13 4260
    Revision: 91H13426 Serial number: 003620G3CS4V
    Coding: 0071612
    VCID: 428F4E3B641F
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0013142
    VCID: 418D41376119
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    1 Fault Found:
    00888 - Wiper Switch for Intermittent Operation (E22)
    014 - Defective
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 2240G004009912
    Coding: 0002413
    Shop #: WSC 00646 210 99117
    VCID: 3B7133DF03F5
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 3300106C110655
    Coding: 3F3F03CA07002103
    Shop #: WSC 06314 123 12345
    VCID: 2F69178FC78D
    1 Fault Found:
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 13
    Reset counter: 246
    Mileage: 104040 km
    Time Indication: 0
    Date: 2012.01.27
    Time: 00:09:37
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20004 Serial number: AUX7Z0G0FN80RO
    Shop #: WSC 00000 000 00000
    VCID: 3B7133DF03F5
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
    Component: RNS-E HIGH EU H80 X---
    Revision: 20S Serial number: AUZBZ7K4100844
    Coding: 0205717
    Shop #: WSC 06314 211 03176
    VCID: 3F8947CF17ED
    3 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 84
    Freeze Frame:
    Voltage: 11.80 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 246
    Mileage: 104040 km
    Time Indication: 0
    Date: 2012.01.27
    Time: 00:08:01
    Freeze Frame:
    Mileage: 104040 km
    Count: 2701
    Clock: 00:07
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 104217 km
    Time Indication: 0
    Date: 2012.01.31
    Time: 12:08:23
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000760
    VCID: 408B44336A13
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.079 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 356525E725D1
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H08 0070
    Coding: 9980202002186D098505489FC637
    VCID: 3F8947CF17ED
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH04 0180
    Revision: 00003 Serial number: 30674697024710
    VCID: F1ED51F79139
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000760
    VCID: 418D41376119
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205717
    VCID: 3F8947CF17ED
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 84
    Freeze Frame:
    Voltage: 11.80 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 246
    Mileage: 104040 km
    Time Indication: 0
    Date: 2012.01.27
    Time: 00:08:01
    Freeze Frame:
    Mileage: 104040 km
    Count: 2701
    Clock: 00:07
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 104217 km
    Time Indication: 0
    Date: 2012.01.31
    Time: 12:08:23
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000216
    VCID: 408B44336A13
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000216
    VCID: 418D41376119
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
    Component: FSE_255x BT H26 0290
    Revision: 00000000 Serial number: 00000005101636
    Coding: 0011402
    Shop #: WSC 06314 211 00000
    VCID: 3B7133DF03F5
    End ---------------------------------------------------------------------
    Many thanks,
    DME
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,654
    9,647
    Hi, welcome to ASN. Glad your enjoying the forum. Someone will be along soon to help you out. :)
  3. NHN
    29,331
    1,716
    Sorry, but its not genuine, its a fake illegal cable, please use genuine & I'd be happy to help.
  4. dme
    dme New Member
    What a k**b, he told me it cost him 300 quid from Ross tech. If I'd known it was fake I wouldn't have asked him to code the car in the first place. That probably explains why it's all gone wrong.
    Anyone in Gloucestershire available to do some coding?
    Sorry for wasting your time.
  5. NHN
    29,331
    1,716
    I have to ask, you spent how much money on mfsw, bt & rns-e, why dont you just by vcds & do it yourself.
    He bought it from RT direct for £300, well according to the info I have about the cable, its a clone, unless he can prove to the contrary its not.
    I travel about & would have done it today, but too late now, can always come out & do it, but its not a beer tokens job for me.
  6. dme
    dme New Member
    I've bought the bits over time. I would love to buy it for myself; thing is I'd only use it once. Would just like to get it fixed and leave it at that.
    I've spoken to my so called mate, he now say he bought it from a guy from eBay who 'claimed' to have bought it from RT.
    Without telling me too much, I would be very grateful if you could tell me from the info above if the car is safe to drive? I take my kids to nursery in the Audi!
  7. NHN
    29,331
    1,716
    Yeah should be fine to drive as long as steering isnt heavy.
    I would happily drive over & fix it for you, but at a cost.
