code poping up on the odometer
97_A4_1.8Turbo Dec 18, 2007
  1. 97_A4_1.8Turbo
    97_A4_1.8Turbo Member
    50
    there is a code that is poping up on the odometer its "ln l" its coming up right umnder the millage of the car when i start it up it flashes for a while.
    does any one know wat the code means?
  2. Road Razor
    Road Razor Member
    411
    Cars without DIS will show In 1 or In 2. In 1 = Inspection 1. Your car is due for a service.
  3. kninio
    kninio Member
    96
    and what is dis , and cars with dis showes what
  4. RGBArgee
    RGBArgee Guest
    DIS is dat thing called a 'Drivers Information System' and in this case DIS shows you dat a service 1 is needed.
    Cheers:hubbahubba:
  5. moschino
    moschino Member
    252
    Hi,
    Below is copy of the instructions on how to reset the inspection service light from a post in the Diesel section. It might be worth a try!
    Press and hold the right button. (odometer reset)
    now switch on the ignition
    (oil lamp will not flash, but on at all times)
    press the right button again
    (insp is now displayed)
    pull left button. (clock set)
    (------ are now displayed)
    Pull left button again
    You might have to try this a few times to reset everything (oil & in1).
    This works on my A4 tdi (110bhp) but should work on all.
    Jim.
  6. Siena
    Siena Active Member
    2,626
    Original poster's car is fairly early, so manual re-set MAY not work.
    Manual re-set became European legislation from about '98 - i.e ALL cars manufactured after this date had to allow the owners to re-set the service interval without special equipment, in this case, diagnostic equipment.
  7. billybravo
    billybravo Active Member
    1,045
  8. JSWD32
    JSWD32 Member
    41
    Hi does anyone know what In 2 means on the odometer?
    thanks
    Jonathon
  9. moschino
    moschino Member
    252
    Inspection 2 Service required.
    I assume your service book should advise what is required.
