In short: air bag liight is on, vcds lite says 65535 Ross tech wiki says:
[h=1]65535[/h]
[h=2]Internal Control Module Memory Error[/h] [h=3]Internal Control Module Memory Error[/h] [h=4]Possible Causes[/h]
what is your experience? faulty module or dodgy wiring? is this the classic under seat connector or something else?
[h=1]65535[/h]
[h=2]Contents[/h] [hide] |
- Wiring from/to Control Module faulty
- Voltage Supply and/or Ground Supply faulty
- Control Module faulty
- Control Module Housing leaky
- Check/Clean Wiring from/to Control Module
- Check Voltage Supply and Ground Supply including the Main Supply/Connections at the Battery
- Replace Control Module
