Code needed for egr shutoff on A4 2.5Tdi Quatt
Mackers Dec 16, 2011
  1. Mackers
    Mackers Member
    291
    hi all as above, i have an audi "X"Reg A4 2.5 Tdi Quattro, basically i'm going to see a mate tomoz in manchester who has a full Vag-
    Com, but we're not sure how to shut the EGR off, any help and codes appriceated.
    Many Thanks
    Wayne.
  2. dunk
    dunk Member
    770
    im pretty sure this isnt a vcds thing - its coded within the ecu programming and needs a remap to remove the function, along with a physical blanking plate - thats certainly the case with later PD cars that ive had
  3. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    On the Ross-Tech site (TDI VCDS Info) there is a coding value to change the valve duty cycle, effectively turning off the EGR. The value given doesn't work for the 2.5 V6 TDi, but go for the highest value possible.
    The login code for the AFB engine is 26242, not the value in their example.
    See Engine Adaptions Login for my inputs
