Chiefnutter
Wondered if anyone could help with checking the clutch switch on my 2006 A3 2.0tdi 8p ?
Does anyone know how many tests that can be done on VCDS to check that the switch is working correctly ?
The only answers ive found on here relate to the 8L & dont work on my 8p
The only 2 I've found in the measuring blocks is 006 & 022 ...?
but ive read this on the ross tech website & am wondering if i should be testing the switch differently ?
"Some of the newer Engine Control Modules may use the UDS/ODX/ASAM protocols. Those modules do not support conventional Measuring Block Groups. Advanced Measuring Values will be used instead and you will check the boxes for CCS (or similar) to locate and view the readings."
Any help would be appreciated really....thanks ;-)
