Clutch slipping advice
imy2k Oct 14, 2013
  1. imy2k
    imy2k Member
    30
    Hi all .
    Recently my Audi A3 clutch has started to slip in high gear and the the biteing point has come very high. I just was wondering would i need to change the flywheel aswell as it is a dual mass . I have had no problems with the flywheel juddering or making any noise and the clutch and flywheel where changed in jan 2012 but i think they where second hand. Can i get away with just changing the clutch or will i have to go all in .
    Thanks all
  2. whitex8p
    whitex8p Member
    108
    I would change the flywheel as well mate as the gearbox will be off!
  3. bmh.01
    bmh.01 Member
    291
    17
    You've done half a job before and it bit you in the ass, do a proper job this time. If you'd had new parts last time you wouldn't need to be doing it again.
  4. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,457
    597
    Change the release bearing as well - only £40 or there abouts!
