Clutch replacement on TDi 130 - dual mass flywheel as well?
AndyMac May 27, 2008
  1. AndyMac
    9,832
    46
    Probably need to get this done this year as it's done 190k on the original clutch. Abtech are saying it will almost certainly require replacement of the dual mass flywheel (?) due to the stupid design of the unit, (changed from the B5 which was a simple £130 job).
    Does this sound right, anyone had it done?
    It's bumping the price up to around £700 which just seems ludicrous even by Audi standards.
  2. jase0851
    jase0851 Member
    789
    my mate had this done for 400 at a specialist that was a 2004 tdi 130 sport aswell
  3. AndyMac
    9,832
    46
    Can you find out where for me? Worth a road trip to save £300.
    Abtech are saying the flywheel is around £250 just for the part.
  4. farmerq
    farmerq New Member
    Is the clutch slipping. Is there vibration from the flywheel. Why do you want to change it?
    Dual mass flywheel is around £200 -£250.
    I got one done on a focus for £580 all in. Thats flywheel,clutch and new slave cylinder fitted by local mechnanic. ford where £500 just for the parts and looking£1000 all in for supply and fit
  5. AndyMac
    9,832
    46
    It's not quite slipping yet, but the biting point is becoming very vague.
    Just can't believe Audi changed the design from the very straightforward B5 unit £130 fitted to this ridiculously overcomplicated malarky.
  6. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    if you need the DM flywheel then source it yourself, and supply it to them.
    its only a small bit of extra labour to fit the flywheel while doin the clutch, at least then you know its not overcharged.
  7. AndyMac
    9,832
    46
    Anyone know the part number, cheap supplier etc?
  8. Issac Hunt
    1,162
    Personally I wouldnt bother unless your suffering from vibration etc?
    I changed just the clutch on my old Golf PD130 at 100k miles and the DM flywheel was in perfect condition. I was advised to change it as a 'precaution' but decided against it as the only fault with the clutch was that the bite point was very high.
  9. farmerq
    farmerq New Member
    Its not audi that changed the design. Its the common rail engine that dictates the use of a dual mass flywheel. Audi,vw,bmw,ford,toyota,peugeot etc all use dual mass flywheels on the common rail engines. Takes the excessive vibration out of the driveline. My mums focus only did 55k before it needed a flywheel. Mates car needed one at 80k. Most of the flywheels are made by the same company, doesn't matter what make of car you have. The biggest cost associated with a clutch change is labour, so for an extra £200 i would say fit the flywheel.
