Clutch replacement labour costs?
akash_sky1 Sep 22, 2010
  1. akash_sky1
    akash_sky1 Active Member
    1,181
    Hi I am getting my Sachs clutch and new DMF fitted sooon just wondering what I should expect to be quoted in the region of for the labour costs?
    cheers
  2. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    It takes about 5 hours to do a complete clutch install on a quattro for the labour. It can be done a lot quicker if they know what they are doing and everything goes to plan.
  3. akash_sky1
    1,181
    Well I'll what my usual Audi specialists say to that....hopefully it'll go to plan unlike my DP which took them ages
  4. nik patel
    nik patel Member
    240
    15
    You might wanna change the slave cylinder at the same time.
  5. akash_sky1
    1,181
    Getting a good friend/mechanic to do this now..getting release bearing obv but not changed slave cylinder before when I had a new clutch?
  6. devonmikeyboy
    1,245
    Why would you change the slave cylinder ?
  7. akash_sky1
    1,181
    Yeah I wasnt aware you needed to do this routinely as a precaution like with the release bearing?
    Getting a friend/mechanic to fit clutch AND H&Rs for 220-250 ish. On a side note...the DMF is one HEAVY piece of kit. Must loose a good 5hp atleast just spinning that badboy.
