Clutch Release Bearing? And Failed MOT!
bhavin1986 Mar 24, 2010
  1. bhavin1986
    bhavin1986 BBP
    464
    Had my MOT today. Failed due to rear springs and ARB Bushes. Did have a little rattle, which will hopefully disappear with the ARB bushes being sorted. I can get hold of the bushes for £15 for the pair for the daelers, and the rear springs for £50 a pair from Euros. Dealer quoted me £67 for each coil! No thanks...
    I have a whistling noise which disappears when the clutch is depressed. I've been told that its the clutch release bearing and should replace the clutch at the same time as having this done. My question is that I've had my Clutch replaced 15k miles ago, when I had to replace the GearBox, is it worth replacing the clutch already? And if so, what kind of labour charges should I be expecting? I've been quoted £150 for labour.
    Cheers all.
  2. Broken Byzan
    13,244
    468
    What size engine is it?
  3. bhavin1986
    bhavin1986 BBP
    464
  4. Broken Byzan
    13,244
    468
    the release bearing on a 1.6 is behind a cover on the end of the gearbox.Remove the passenger front wheel and the splash guard and there is a cover visable on the end of the box, the bearing lives in there.
    No box out to change, no oil loss, around £5 from GSF/ECP
  5. bhavin1986
    bhavin1986 BBP
    464
    I can see a green plastic part on the end of the gearbox with a vw logo on, is this the cover?
  6. Broken Byzan
    13,244
    468
    Yarp!! Suprised the box refurber didn't change it tho
  7. bhavin1986
    bhavin1986 BBP
    464
    Excellent. Cheers for that mate! The noise only started around a month ago, so maybe he did replace with a cheap one? Who knows...
