clutch problem ????
gracelea68 Oct 31, 2012
  1. gracelea68
    gracelea68 New Member
    23
    hi all my name is mark im new to this forum
    i have owned audis for around 5 years now my first was an audi a3 1.8t, never had a problem with it.
    this week i bought an audi S3 iv only owned it for 4 days its been great!!, last night i took it for a run everything was fine, i pulled up at my house and as i came up the road changed into second the clutch felt funny, changed to third even funnyer and as i came to a stop it was gone, its now flat to the floor i can pull it up and back down but there isnt anything there wont go into gear,it was like (evry time i changed gear i was pumping the fluid out) and i noticed there was a little steam/smoke cuming from under the bonnet,
    was wondering if maby a pipe has blown off?? were do i check first?
    i think the slave cylinder has gone i hope not but hey ho??
  2. gracelea68
    23
    its an x reg 2000
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Look around the gearbox linkage area they usually pop there or the pedal snaps..
  4. gracelea68
    23
    ok cheers ill look as soon as the mrss gets home she took keys with her to work lol only got master key ere, will it set the alarm off if i open it manualy
  5. s3dave
    10,110
    736
  6. AwesomeMike
    AwesomeMike Member
    165
    Not sure if it would be much help, but if you are in the Manchester area, we would be more than happy to have a look at the car and find the fault!
    As above there are a couple of common things that they do!!
    Either way, hope you get it sorted and if there are any parts you need give me a holla I will look after you the best I can :)
    Awesome Mike
  7. Broken Byzan
    13,237
    465
    Ahh the famous slave cylinder failure. Box out to inspect, but a visual check should reveal fluid from the box/sump join
  8. gracelea68
    23
    not far away lol wrexham north wales, will be looking for a clutch, slave cylinder and dualmass flywheel if you got a price on any of them lol cheers
  9. gracelea68
    23
    dont think there is any fluid on the sump join??
  10. AwesomeMike
    AwesomeMike Member
    165
    Send you over a quick PM :)
    Awesome Mike
