Clutch position sensor??
S3 Paul Oct 26, 2011
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    My 2001 S3 has developed the usual rev increase when i put the clutch down to change gear.
    Kind of like ive not backed off the gas quick enough.
    I seem to think ive heard/ read about this being a switch on the clutch pedal?
    Does anybody know if this is right? And idealy the actual name or part number of the part / parts needed.
    Chears
  2. richieb138
    richieb138 Member
    31
    This ones a bit of a funny one. Some people seem to report that changing the switch doesn't help, other people think it's supposed to happen on these engines, so i'm not sure??
    When I had mine changed it helped a bit, but the 'problem' was still there. It seems to be pretty bad now a year on - might have to have a look at it again....
    Also, apparently you can replace the switch with a new one, but if it's not set right when you install it, you won't fix the problem
  3. S3 Paul
    2,825
    107
    My friend used to work for an audi tuner so i will intrust him with the job.
    I need to replace the brake pedal switch too so was looking to do both at the same time.
  4. BENJAMIN
    BENJAMIN Active Member
    503
    93
    It's either a 'n249 mechanical malfunction' or 'clutch pedal switch implausible signal' that gives that over revving between gear changes. Give it a scan to see which one it is. Arguably best thing to do is put a new switch in and do the n249 bypass, problem solved! Lol.
  5. S3 Paul
    2,825
    107
    I fitted a bew N249 valve last winter , The car shows no fault codes.
    its just if i can stop it ... i would like to
  6. BENJAMIN
    503
    93
    Hmm bizarre, clutch switch is less than £10 from Gsf so probably worth a punt for that price!
  7. S3 Paul
    2,825
    107
    Ah, I was told they are dealer only?
    If they are only £10 its a no brainer.
    I would do the N249 bypass but couldnt find an easy guide for the AMK/BAM engine so decided... if it works dont break it.
  8. BENJAMIN
    503
    93
    Yeah that's what Gsf told me but I took it out and gave them the part number and they do actually do it as its actually a mk3 golf part.
    N249 bypass on the amk/bam is the easiest one to do. Where abouts are you? I'd happily do the bypass for free if you were local.
  9. S3 Paul
    2,825
    107
    Im in sheffield but travel a little
  10. BENJAMIN
    503
    93
    I'm in Brighton! Lol. I'll post a pic of my delete tomorrow on this thread. It's very easy, you only need about half a metre of 3mm vac pipe.
  11. S3 Paul
    2,825
    107
    Benjamin...
    Did you get chance to take that picture????
    I would love to see if its as easy as you say, I will try it .
