Clutch peddle switch...
warleydaddy May 19, 2010
  1. warleydaddy
    warleydaddy Member
    211
    What does this control, bar canceling the cruise control???
    Pete..
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
  3. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    Controls the cruise control disengage, as well as allowing the ECU to know when the clutch pedal has been depressed.
    This helps the engine to rev match correctly for gear change, as it knows a) when the pedal is depressed and b) when the pedal is released.
    If you have a faulty clutch switch, expect the engine to seem unhappy at gear change. Fault codes for the clutch switch will appear in the engine fault code controller, so you can have a look for issues there.
    Bear in mind that S3s and A3s without cruise control also have clutch switches.
