Clutch Pedal - Very strange...
beanoir Dec 5, 2011
  1. beanoir
    beanoir Large Member
    2,171
    31
    Something quite odd happened when I got back to my car this evening at the station.
    I jumped in the car and went to put my foot on the clutch before starting her up as normal, but the clutch pedal wasn't where it normally is, it was weird I actually thought at first i'd accidentally moved my seat back, but then I realised the clutch pedal was fully depressed.
    Now I know the clutch pedals are prone to breaking in these cars and the clutch master cylinders can give up too, but the when I bent down and grabbed the pedal it just came back up with a slight pull. It seemed to be jammed/stuck, but I have no mat in at the moment and I can't find any reason for it to have got jammed.
    I drove it home without issues and went to the shop and it seems fine.
    Has anybody else experienced this before or is it a first symptom of something worse to come?
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Yes its been mentioned before without further incident....:think:
  3. Gops
    3,198
    666
    This may not be much help but that used to happen to my fiesta, turned out to an hydraulic issue. Just bled the clutch and it never returned. Probably not much help since different car but worth mentioning.
  4. Chris-gsxr
    Chris-gsxr Member
    57
    Any more on this? It just happened to my 09 a3 s line
  5. pattso187
    pattso187 New Member
    Hi Chris,
    Like Gops has mentioned if the pedal can be lifted back up then works as normal this will generally mean that there is a hydraulic issue. Worst case the slave bearing within the bellhousing is leaking - gearbox needs to come out for replacement. Your best bet is to bleed the clutch then monitor it. If its still occuring follow the clutch lines from the master cylinder to the gearbox and ensure there aren't any external leaks. If you can't see any and your really keen you can disconnect the feed to the master cylinder at the brake fluid resevoir, catch the escaping brake fluid then attach a clear container to the feed and fill to a set level and mark this on the container. Then actuate the pedal 10 times or so and see whether the level drops. If so you've got a leak somewhere. If not then you need to check the crank end float and cross all your fingers and toes while doing so.
    Cheers,
    Patrick.
  6. Chris-gsxr
    Chris-gsxr Member
    57
    It's only happened once so hopefully it's nothing to serious. Ill see how it goes over the the next few weeks. Cheers for the info
  7. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,197
    2,013
    Mine did this within a month of first buying it and saw it twice in five years after that so I wouldn't be too concerned. (8L)
  8. Chris-gsxr
    Chris-gsxr Member
    57
    Now that's the type of answer I was hoping for. I'm a fan of the "ignore it and hope it goes away approach". Lol:)
  9. voorhees
    16,197
    2,013
    ha ha yeah works to an extent but I know if it was crunching into gear or staying down all the time I'd be after a new pedal/cylinder Chris
  10. Chris-gsxr
    Chris-gsxr Member
    57
    Ye I'm only kidding. It's fine not. It was really strange. I changed down from 3rd to 2nd and the pedal was kind of stuck. Only for a second. I pushed it again and it popped back up and has been fine since. It goes into gear fine so I'm hoping for the best but if it happens again ill have it looked at.
  11. voorhees
    16,197
    2,013
    Oh and ermm your 09 model is 6 years ahead of this sections last models Chris
