Clutch pedal sticky
r4vvm Jun 9, 2014
  1. r4vvm
    r4vvm Member
    76
    My 2.0 TDI clutch pedal has started to stick when changing gears just after the biting point.
    It seems to get stuck near the top after changing gear and then pops back up after a split second.
    Any ideas what this could be?
  2. Marshy
    Marshy Settled in Audi RS3
    1,352
    470
    Sounds silly but the pedal isn't catching your floor mat and lifting it up when releasing the pedal.
  3. r4vvm
    r4vvm Member
    76
    Nope definitely not the floor mat. Just feels kind of sticky, changes gear fine but seems like it is catching somewhere on the way up
  4. pafcpilgrim
    pafcpilgrim New Member
    10
    Hi mate did you ever solve this, I have the same problem on my TDI. So interested to know if you ever fixed it.
  5. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    ive had this a few times and its been the slave cylinder, 6sp is box out job
  6. S3_Mat
    S3_Mat Active Member
    550
    192
    43
    I would try bleeding it first but it certainly sounds like the slave not returning properly.
  7. pafcpilgrim
    10
    Thanks Phil. mine is the 6sp box too. So did you have this done and if so how much?
    S3_Mat yes reading through bleeding might be a possibility the case is on 170k and I don't have any record of clutch replacement so over the years could well be air in the system. Usually happens when its cold like it has been these last few days.
  8. phil miller
    1,211
    166
    I own a VAG indy Garage in Launceston (20 miles from plymouth) ive done this before and dependent on what the customer wants to do, we can just replace the slave (not really a great idea tbh) some want the DMF and clutch replaced some want us to test the DMF and if it passes to just replace the clutch kit, its a tricky one, as imho if a box comes out for a slave issue then replacing the clutch and DMF is future money saving
    S3_Mat likes this.
  9. pafcpilgrim
    10
    Hi Phil, yes not too far. So lets say replace all that what are we looking at or at least a breakdown of the costs?
    Clutch and fly wheel do seem fine but i'm not sure how to properly test this.
  10. phil miller
    1,211
    166
    Ok, would have to double check price of the parts but iirc the parts are around £450, Labour £180, so id say a worse case of £630, Labour is inc VAT although like i said id have to check the cost of DMF, clutch and slave price to give 110% quote :)
  11. Randomage
    Randomage Member Supporter
    65
    17
    I had the same issue on my FSI just before christmas, pedal stopped returning entirely eventually. There's a plastic clip that gets damaged, and clutch master/slave cylinders can accentuate the problem. I took it to a good independent garage, cost me less than 160 to get it all sorted :encouragement:
