Clutch pedal sticking
monty77 Feb 20, 2005
  1. monty77
    monty77 Member
    391
    Had it a couple of times today .. clutch doesn't return to normal height occasionally - not good today when I was launching enthusiastically, nasty smell of burnt clutch!
    Anyone know what casues this? And whatever it is is it likely to be covered by Audi warranty?
    Cheers!
    Adam
  2. S3tony
    S3tony Member
    395
    mines done this once almost stuck to the floor. was really cold at the time and had just set off, just got my foot undereath and pulled it up. hasnt done it since, i just put it down to cold.
    cheers tony
  3. HTC
    HTC Active Member
    3,428
    9
    Do a search on here. There have been a few threads about clutch pedal faults.
    If I remember, they can break causing this and other syptoms.
  4. marctwo
    marctwo Member
    410
    Mine creaks. Never had it stick though. Did yours creak before it started sticking? Again this seems to be related to it being cold.
  5. Defratos
    Defratos YouÂ’re Dethpicable!!
    2,232
    Yeah mine's done the same as S3tony, I also put it down to the cold and just pull the clutch back up from underneath (gently)
  6. Cage
    Cage Member
    95
    I had the same symptons, like Andy it turnt out to be the master cylinder also.
  7. monty77
    monty77 Member
    391
    [ QUOTE ]
    [/ QUOTE ]
    Thanks chaps ... I was thinking slave cylinder but I'm not yet familiar with the setup on the S3.
    Did a search and most seem to be problems with the pedal or the pedal box - cant see it being that as it's intermittent.
    ..will get on the blower to Audi this morning as I dont want to be left stranded - hate dealing with those clowns but needs must.
    Cheers,
    Adam
  8. monty77
    monty77 Member
    391
    Well they're picking the car up from me tomorrow to take a look, bloke on the phone actually sounded like he'd changed the oil on a car once and said he thinks it's the master cylinder too and it should be covered by the warranty.
    Fingers crossed - will I actually get what I want without having to make a scene in the dealers?
    Cheers,
    Adam
  9. HTC
    HTC Active Member
    3,428
    9
    Cool. Let us know how you get on.
  10. HTC
    HTC Active Member
    3,428
    9
    Cool. One to remember for the future if other people have the same prob.
  11. monty77
    monty77 Member
    391
    Well the called later in the afternoon to say they had located a part and fitted it yesterday.
    No more sticky pedal and also the slight clunk that I assumed was normal when dropping the clutch has vanished which is nice.
    Can someone tell me where the clutch master cylinder is located in the engine bay?
    Cheers,
    Adam
  12. AndybS3
    AndybS3 Member
    233
    Directly behind the clutch pedal Adam, there's a rod that goes from the pedal into the master cylinder
  13. monty77
    monty77 Member
    391
    [ QUOTE ]
    [/ QUOTE ]
    Thanks, I like to have a nose around after anyone works on the car to make sure that new bits look new /ubbthreads/images/graemlins/smile.gif
    Cheers,
    Adam
