Clutch pedal on the floor!
Pete20vt Sep 20, 2011
  1. Pete20vt
    Pete20vt Supermoto Junkie
    121
    Clutch pedal went to the floor while driving this morning, no loud noises or cracks, quick look at the pedal in the dark and both the pedal and the white plastic clip look ok at a glance. Limped the car home with no clutch at all and when I arrived there was a faint smell of burning clutch. Clutch has been fine (no slippage) up until now.
    How can I diagnose pedal, master cylinder, slave cylinder or clutch?
  2. Pete20vt
    121
    Also there is a very slight noise when the car is idling now, sounds like the clutch is ever so slightly engaged.
  3. <tuffty/>
    20,840
    3,677
    Master cylinder by the sounds of it...
  4. Pete20vt
    121
    Doh! Something Bill will do? (thanks for the reply btw)
  5. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    Mine did this, was a failed slave cylinder. If it is the slave its a gearbox off job.
  6. Pete20vt
    121
    Really hope its not the slave.
  7. <tuffty/>
    20,840
    3,677
    Yeah, Bill can do this... :)
  8. liquids3
    liquids3 Member
    931
    22
    My a3 8l clutch pedal went to the floor from snapping,is this what you meen its gone to the floor?
  9. Pete20vt
    121
    Just dropped it down there, fingers crossed its not too expensive.
  10. Pete20vt
    121
    No its not the pedal failing, its something up with the system. Master cylinder, slave cylinder etc.
  11. liquids3
    liquids3 Member
    931
    22
    Oh so its more the pedal biteing low,ok
  12. Pete20vt
    121
    No the clutch is not biting at all. Its dropped to the floor, slave cylinder has gone, dropping all the oil out. £££
  13. Pete20vt
    121
    Dropped it down there earlier, turns out its the slave cylinder, doh!
    Anyone wanna buy an S3? lol
  14. <tuffty/>
    20,840
    3,677
    Whoops....
    Bad luck d00de..
  15. badger5
    9,321
    1,891
    slave cylinder and release bearing totally shagged... worn thru
    its nearly back together now..
    fingers crossed alls well when we bleed it back up with its new bits
  16. Pete20vt
    121
    Fingers crossed :)
