Clutch pedal grating
subtle Feb 15, 2010
  1. subtle
    subtle Member
    41
    Hey, just purchased an A4 1.9 tdi (130) and have a small niggle, the clutch pedal feels like it's grating when being depressed, it feels like it's a worn cable but I believe the clutch would be a hydraulic mechanism?
    Just wondered if anybody has had a similar problem or would have a cure?
    Cheers.
  2. Nutkin
    Nutkin Member
    830
    sometimes they flapsin the hydrolics can get a bit stuck, does it loosen up when the car is at running temp. ?
  3. subtle
    subtle Member
    41
    Thanks for the reply. No unfortunately the problem still persists when warm, just wondering if there may be a rubber or bush on the pedal mechanism that may need a bit of lube?
    Only picked the car up on Friday so not too familiar with it yet!
  4. subtle
    subtle Member
    41
    So, I've just driven the car again tonight (it's the wife's car) and the grating seems to only be apparent whilst driving, when the car is stationary dip the clutch pedal and all seems ok.
    I have noticed a small amount of clutch judder also whilst pulling off, I've tried to see if the clutch slips by accelerating at full throttle in 6th at low revs and the clutch does not appear to slip at all. So it has left me a little baffled as to what may be wrong.. clutch, pressure plate??
    Any help would be appreciated!
    Glen.
  5. subtle
    subtle Member
    41
    An update on this problem... knackered Dual mass flywheel!
  6. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    Did you have it replaced?
  7. Mr Singh
    Mr Singh Member
    87
    Whats the mileage?
  8. subtle
    subtle Member
    41
    Yes, unfortunately the DMF & Clutch were both replaced today at great expense! The car has only done 43k, I was also informed that this was probably caused by the previous owner riding the clutch too much.
