Clutch on the way out, what are my options of a new one?
Tony toss Feb 20, 2013
  1. Tony toss
    Tony toss New Member
    17
    Hi,
    My clutch has just started slipping in 4th above 3k RPM so it is time to change it.
    What options have I got a replacement kit?
    Iv read that people are converting to solid mass flywheels, what is the reason for this and advantages/ disadvantages?
    Its a 1999 pre facelift 1.8t agu engine
    if anybody could suggest a kit or the parts in need and where to get them that would be awesome.
    Cheers Tony
  2. joebickerton89
    joebickerton89 Member
    123
    Not sure about a single mass flywheel mate but my clutch went recently and at the weekend i got a solid mass flywheel conversion kit with valeo clutch capable of handling decent power its in the car now alot of people seem to have done it without any problems this is the kit i got it comes with everything you need to just remove your old bits and fit all the new.all the best
    AUDI A3 1.8T 1996-2003 AGU, AQA, ARX, AUM NEW SOLID FLYWHEEL & VALEO CLUTCH | eBay
  3. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    you can get a g60/vr6 conversion for cheap.
    i got my flywheel for £10 and the vr6 clutch kit for 150
    the rest is labour. it feels so much better than standard clutch. do it! :D
  4. Prawn
    11,580
    3,548
    get an ABF flywheel from a breakers TJ, centre bolts and pressure plate bolts for the same from audi or TPS, and an LUK VR6 clutch kit from GSF for £90.
    Should cost you well under sub £200 all in, and gives a lighter pedal feel, and a clutch capable of withstanding 300bhp / 300lbft. More than you'll ever need :)
  5. Hi, will this be the same for a BAM engine
  6. Prawn
    11,580
    3,548
    no mate, I'm afraid not.
    5 speed agu engines have an 02J box, and a 228mm clutch setup.
    6 speed BAM engines have an 02M box, and a 240mm clutch setup, and a different style of slave cylinder also. sorry!
  7. Nice one cheers.
  8. S3Zek
    S3Zek Member
    410
    Like prawn said, I payed 5 times that for the same sort of thing, there is slightly cheaper options tho if you want it to handle bigger power, (as in what I paid)
  9. Gops
    3,198
    666
    When my clutch is due, I'm going for tuffty's set up. Sach's paddle clutch, oem plate and fly (I think). Seems pretty decent!
  10. S3Zek
    S3Zek Member
    410
    To be honest mate the top one could be similar to mine (other than the duel mass) and the bottom make (tecknithingey) I've never really heard good things said about them but that's just the impression I've got, mine is http://www.sachsperformance.com/Sac...rmance-Clutch-Kit-One-Mass-Flywheel::156.html
  11. S3Zek
    S3Zek Member
    410
    The next thing up from my kit is with the sach paddle instead of the organic (the same one that tuffet runs with a duel and standard pressure plate I think?)
  12. Tony toss
    17
  13. smurfworth
    smurfworth Well-Known Member Audi S3
    1,939
    543
    Either the first or second link. Most go for the Sachs. You don't exactly need the Kevlar
  14. basil brush
    basil brush Active Member
    525
    170
    43
    Evening :)
    rather that start a new thread , I'm bumping this one :0
    my agu's dual mass is making some nasty noises so its smf time :)
    im going to go the vr6 route but need to know what in earth a "ABF" flywheel is ?
    Also is it a golf or corrado clutch kit I need if they are different ?
    Lastly I realise I need bolts too so which ones ? Vr6 pressure and what flywheel ones ?
    Cheers baz :)
  15. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    abf is the enigne in the mk3 2.0gti, fantastic motor off topic, the car in genreal about as fast as a 1.8t!
    any way flywheel bolts and pressure plate bolts from a abf too. the bolts on the dmf are longer
    least you aug (8l) guys dont need to have the flywheel machined :( extra £80 on top!
  16. basil brush
    525
    170
    43
    Jolly good , thanks for the informative answer ;)
    off to eBay as we speak :)
    baz
  17. Dr. Hell-No
    Dr. Hell-No New Member
    Basil, just wanted to make clear its the 16v fly you want, which differs from the 2.0 8v gti setup.
  18. boost-addict
    1,000
    39
    sorry didnt mention that, i do miss my mk3 lol, revvy little engine!
  19. duff duff
    duff duff New Member
    Ive also got an1994 aug ,clutch has gone, I was woundering would the fly wheel fit or would it need modifing to fit
    Cheers liam
  20. boost-addict
    1,000
    39
    Sorry to be blunt but reread the first post and then the posts following
    you will see the op has a 1999 preface lift agu engines a3 and as said those clutch arrangements fit with no changes to other compnents are required
