Clutch just went...
vfr800 Mar 29, 2014
  1. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    Hi
    Just driving around as normal, pressed the clutch to change up. Pedal stayed down and the car is stuck in neutral.
    I coasted to a stop, off the dual carriageway fortunately, and took a look in the engine bay.
    Brake fluid sprayed around the bleed nipple area.
    It looks like the clip that keeps the bleed pipe attached to the clutch slave solenoid, where it enters the gear box, gave out and the pipes separated.
    Is this a common problem?
    So, is it just a new springy c clip and a bleed from the clutch bleed point or will I have got air back in the system?
    Liam
    Just waiting for RAC ATM.
