Clutch fluid?
Lex May 24, 2009
  1. Lex
    Lex Member
    365
    I was just driving and felt the clutch stay at halfway when my foot was completely off. So i pumped the clutch abit whist i was stoped and it feels fine now but my question is
    Where is the clutch fluid? so i can fill it up
    im not a mechanic so please forgive me for that stupid question.
    cheers
    lex
  2. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    I could be wrong but sounds more like air in the system to me that will need to be bleeded out.
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    The clutch shares the same fluid reservoir as the brakes so its the cap on the master cylinder. You may find this is ok tho, if you were short of fluid the pedal would be very light and on pressing the clutch the level would shoot straight to the floor. Cant really suggest what it could be, possibly the clutch slave cylinder at the pedal?
  4. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    Cluch and brake use the same fluid - DOT4 IIRC
    Its on the back left of the engine...against the firewall with a yellow cap.
  5. Lex
    Lex Member
    365
    cheers kaz, the fluid is all fine
    but my clutch is getting worse now, it now needs more pumping to keep running and just 5 mins ago on my way home it wouldn't let me select first.
    has any1 else had these problems with a clutch or slave cylinder ?
    lex
  6. RS_Cosworth
    RS_Cosworth Member
    124
    Rebirth of an old post :blush: Lex, what did this problem turn out to be as I'm going through the same sort of thing at the mo with mine :sob:
  7. Khufu
    5,704
    31
    i'm guessing slave cylinder LOL
  8. RS_Cosworth
    RS_Cosworth Member
    124
  9. Lex
    Lex Member
    365
    it actually turned out to be the brakes
    the discs and pads were getting bad but still felt alright but the car senses this and stops the clutch from working so you cant drive the car, just a safety feature so your brakes dont fail whist being driven
