clutch delay valve - new simple easy mod
superkarl Mar 21, 2013
  1. superkarl
    superkarl MAN OF STEEL
    9,553
    2,453
    i had this valve fail some time ago in the middle of town, its split, and i was stranded.
    so i replaced the valve with the straigh brass fitting pictured below:
    This is a popular mod with the BMW boys as far as im aware. i was reminded of it last night whilst reading a build thread on PH, so i took that pic today.
    it is located on the firewall , next to your abs pump. Basically, it restricts the flow of fluid when bringing the clutch up, to sort of 'dampen' the clutch, hence the name 'clutch delay valve'.
    in bypassing this you will notice a sharper response from your clutch, feels very good, alot more feel through the pedal.
    Just putting the word out there for people to try it.
    over and out
  2. Jason.s
    Jason.s Active Member
    2,879
    348
    Ah yes i`ve read that same thread on PH and thought it sounded like a good thing.
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Yeah easy mod on the BMWs, never felt it much on my car
  4. Dani_B19
    9,336
    391
    So anyone else done this yet? Also would the clutch need bleeding afterwards?
  5. .Ben.
    .Ben. Member
    118
    ^ Exactly what I was about to ask! Surely, by opening the circuit, you're introducing air? Not good in a hydraulic system, right?
  6. James TQ
    James TQ Member
    561
    thats probably the difference your feeling :p
  7. Dani_B19
    9,336
    391
    Also where did you get the braided pipe from karl?
  8. hughjass
    hughjass Is there somefin in my teef?
    293
    10
    Would it work on my big boat of a car?
  9. <tuffty/>
    21,576
    4,048
    I think it goes without saying you need to bleed the clutch after doing this mod...
  10. superkarl
    9,553
    2,453
    The atmosphere isnt going to just start filling the fluid system.
    id sprung a leak, fitted that, few pumps of the clutch and it returned, a short drive will say bye bye to any air
    the part i fitted was a fluke just lying around. Il get thread sizes tho this weekend.
  11. superkarl
    9,553
    2,453
    agreed.
    Mine just never needed it
  12. <tuffty/>
    21,576
    4,048
    M10x1 is normal thread size for VAG hydraulic brake/clutch fittings iirc...
  13. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    the joiner can be bought from any motorfactor, its a standard brake fitting thread and pitch :)
    being the clutch you should be able to pump the clutch pedal half a dozen times and it will be fine
    Karl top idea and 'another' on my to do list
  14. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Reckon I will definately do this when I've got my engine out as its something that could potentially go wrong and can't see any downsides to removing it :)
    Top work Karl
  15. chrisw_s3mk1
    chrisw_s3mk1 Member
    62
    ahh this may solve why my clutch is **** ie when i press down it slowly rises back up etc ive already bleed and already changed clutch master cylinder and slave cylinder in new clutch kit and dm where do i get one of these and any how to guide
  16. superkarl
    9,553
    2,453
    Ive wanted to post this because when the valve was removed to fix the leak, and before i knew what the hell it was, i expected the clutch to feel different and maybe feel a bit poo seeing as it was a quick fix with no bleeding. After using the car and being very inquisitive with the clutch it felt great.
    thats when i discovered it wad a common mod amongst other makes. id asked a few lads to do it just to see if i was going mad and they havent done so yet. And the thread i was reading prompted me to do this.
    As stacey said, it wont do any harm at all. Will prob take half an hour and cost a couple of quid (although i dont know where the part is from, it was in my dads tool box, very conveniently), and youl prob never have the issue of the valve bursting leaving you stranded somewere.
  17. allan mc
    allan mc Member
    45
    The first photo isnt found, does anyone have it?
  18. superkarl
    9,553
    2,453
    Il try and find it and update
  19. allan mc
    allan mc Member
    45
    Ah thanks that wiukd be great, uts in the garage now trying to find a leak on the pipe roubd the same area
  20. xpoweruk
    xpoweruk S4 B8 Smile Machine Team Ibis Audi S4 quattro saloon
    2,238
    1,534
    Are the fittings M10x1 ?
  21. superkarl
    9,553
    2,453
    Best I can find of the original valve.
    Passenger side, behind the turbo intake pipe on the bulkhead.
    Il take a photo of the replacement piece later
    taylor855 likes this.
  22. allan mc
    allan mc Member
    45
    Many thanks,that's what i thought it was, ive got a leak on the pipe that runs behind the heatshield coming from that valve, ots in the garage today but they aint looking at it till tomorrow so if you could get a pic i can get them to remove it while they are on
    Allan
  23. S3 Hilife
    S3 Hilife It's an addiction Team Dolphin Grey VCDS Map User Gold Supporter Audi S3 quattro
    745
    350
  24. superkarl
    9,553
    2,453
    Nathan Barnes likes this.
  25. S3 Hilife
    745
    350
    Thanks buddy
  26. allan mc
    allan mc Member
    45
    Garage has done this mod now they cant bleed the system telling me i coukd need a new master cyclinder, dont think they havea clue like, is there a specific way to bleed the clutch?
  27. allan mc
    allan mc Member
    45
    Also pedal is on floor, does it have to be pulled up to bleed?
  28. superkarl
    9,553
    2,453
    if you completely drain the brake system the seal in the MC can flip and totally **** it up.
    Persist tho. and of course it should be up. Dont forget to bleed the MC
  29. allan mc
    allan mc Member
    45
    Think they have done that. Ordering a new mc hopefully will sort my losing the clutch pedal over night problem but i reckon its gonna be the slave cylinder, although the leak is sorted lol
  30. superkarl
    9,553
    2,453
    My current piece in place
    Gops and xpoweruk like this.
