Clutch change - 3.2 Quattro
PhilPD Mar 10, 2012
  1. PhilPD
    PhilPD Member
    35
    Evening all,
    My clutch is going to need replacing shortly. I've found a guide online for changing the clutch on a Mk4 R32. Can anyone who is familiar with the two cars or the procedure of changing the clutch, let me know if they think an R32 guide would be close enough?
    I have done clutches before, but only on older/less sophisticated cars.
    Also, What is the normal procedure with the fly wheels on these? Do people change them as a matter of course?
    Thanks for any thoughts.
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    r32 is similar
    its easier to remove subframe completely to gain access
    if you have gearbox out do flywheel as its preventitive maintenance if it goes in 6mths you will kick yourself
