Clutch bleeding help...
HOTTIGGER Sep 26, 2012
  1. HOTTIGGER
    HOTTIGGER Member
    99
    hi all i need to bleed the clutch on a s3, i hade the brake master cylinder changed a few week ago but i dont think the clutch was bleed propley as the gears seem to be crunchy, i dont want to bleed the brakes again just the clutch, can i do this on my owne with an ezzbleed ? do i just connect the easybleed and open the nipple on top off the gearbox then close it? do i need to press the clutch at any time or do i need some one in the car pressing the clutch? the brakes are a real pain to bleed and im worried if i try bleeding the clutch ill lose the brake peddal again. any advice, thanks in advance..
  2. aragorn
    18,536
    865
    yeh just do what you described and it'll be fine.
    Shouldnt need to touch the clutch pedal, but you might have to do it a couple of times to get a good pedal.
