Clutch and dmf for a3 quattro
James TQ Jul 24, 2013
  1. James TQ
    James TQ Member
    561
    Looking into a stage 2 map in the near future. My clutch isn't slipping at the moment but I want it done before the map,
    Is an s3 clutch the same as a 5spd a3 quattro? I'm struggling to find a clutch and dmf for the quattro can anyone recommend some product or retailers, thanks
  2. djdougalno1
    djdougalno1 Member
    189
    Yes the a3 Quattro 5 speed gearbox is the same casing as the 6 speed so you would need a clutch that fits an s3 the standard s3/tt clutch would be up to the job of a stage 2 map also if you ever need a speedo sensor that goes in the gearbox you also need the 1 for a six speed box even thou it's a 5 speed they are different
  3. James TQ
    James TQ Member
    561
    so i can buy a s3/tt clutch and dual mass fly wheel? do i need a new speedo sensor is it a must? if the clutch says s3 6sp it will fit the a3 quatt? thanks pal
  4. <tuffty/>
    21,161
    3,838
    This is your answer....
    djdougalno1 was saying that should you ever need to buy one then you could source one from a 6 speed box as the 5 speed box in your A3 quatty is an 02M 6 speed box with 6th gear missing...
