Cluster Screen Polish
ScottD3 Apr 5, 2013
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    I'm currently playing about with 2 different clocks and both have really badly scratched faces.
    I don't have a DA, only my hands and a really good right arm.
    Anyone recommend any products to help remove these scratches?
  2. Boon
    Boon Active Member
    441
    59
    Sand the whole thing to remove the scratches, using fine wet and dry. First try 2000 grit if that doesn't work (it will work but take time!) drop the grit down and then back up to finish - use it wet too
    As for polish, Meg's do a plastic restorer, Cerium Oxide works... Have even used AG SRP in the past!
    You can polish it by hand or use a small foam or felt polishing pad in a cordless drill - just use it slowly and keep the plastic cool
  3. _G_
    _G_ Active Member
    876
    Swiss vax mechanical repair is quite good as it has abrasive and filling properties.. agree for polish have used meguiars headlight repair successfully in the past too.
  4. Boon
    Boon Active Member
    441
    59
    A before and after on my mates headlight using wet & dry (sanding wet) and Auto Glym Super Resin Polish on a soft black foam pad in a cordless drill
