Cluster language and airbag light
S4 shqwn Feb 1, 2014
  1. S4 shqwn
    S4 shqwn Member
    33
    Hi guys. When I bought my b6 s4 the cluster language was in German and airbag light comes in after set time. Scan also says module incorrect vin.
    After looking around have come across the software in the cluster goes bad. Known problem. Some say you can re program it through vcds. Anyone any experience with this?
    cheers. Shawn
  2. christof71
    christof71 Member
    60
    What is the year of your car and engine code?
  3. S4 shqwn
    S4 shqwn Member
    33
    Not sure on engine code. It's a 2003 s4 b6
  4. christof71
    christof71 Member
    60
    {Scan also says module incorrect vin} do scan seys incorrect vin in Airbag ecu?
    If yes you can adapt airbag ecu
    [h=3]Channel 081: Vehicle Data Learning[/h]To start the process for vehicle data (VIN) learning, enter/save 02905 as new value.
    Audi A4 (8E) Airbag 9.41 - Ross-Tech Wiki
    language versions also you can change
  5. S4 shqwn
    S4 shqwn Member
    33
    Cant remember to be honest. Just noticed it said control module and immobiliser
  6. christof71
    christof71 Member
    60
    Do your instrument cluster is working properly?
    Do you need change language and reset airbag lights ?
    VCDS Can't reprogram,upgrade ,change software .
  7. S4 shqwn
    S4 shqwn Member
    33
    Had language changed a while back but airbag light comes on after about 10 mins driving. Re sets when ignition turned of everytime
  8. christof71
    christof71 Member
    60
    check faults in adres 15 Airbag ECU .
  9. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    might be best to go through vag com with another similar s4
    that way you should get the correct regional settings
    mine lost it settings once and i had to mess with vag com and copy another to get it correct
  10. S4 shqwn
    S4 shqwn Member
    33
    Anyone near by lol
  11. dualmono21
    1,138
    you can have a look at mine and copy mine if you wish mate
    im just off junction 36 of m1
  12. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,178
    215
    I have full VCDS and can do you a fault code scan, but i'm not too clued up on coding/adaptation.
    Maybe if you can get me a walk-through guide, i can do it for you.
    Shaun.
