CLUNKY CLUNKY, FRONT OF CAR CLUNKS
nick-barnes07 Feb 17, 2009
  1. nick-barnes07
    nick-barnes07 Member
    552
    Hi all, on my s3 the front seems to clunk, it only clunks when the car is lifting of or juddering, i replaced the 2 top mounts, cv boots, and top mount bearings, we have checked all the bushes and that but cant seem to find anything, as i said the car only really clunk's when you are either pulling of from stand still or when the car accelarates and lifts on the front, anyone had this problem?????????????????????????
  2. mat20vt
    mat20vt Member
    450
    engine mounts?:ermm:
    no luck selling it yet nick?
  3. nick-barnes07
    552
    yeah its sold matt, just need to get the mounts done
  4. audi18tdan
    audi18tdan Member
    241
    Hi,
    i also have the same sort of problem but only when going over bumps and only since fitting coilovers and if i remember right it's only on the passenger side and that was the side which went down a hugh pot hole so think it may be the top mount bearing.
  5. btmotorsport
    btmotorsport Soon be christmas!!!!!!!!!!
    164
    arb drop links?? easy fix if it is
  6. jcs356
    jcs356 Brum brum
    2,725
    65
    Another vote for the ARB drop links.
  7. nick-barnes07
    552
    ill order some from my local tps tommorow
  8. Mr.G
    Mr.G Well-Known Member Team Sepang Audi S3
    1,434
    228
    Mine needs top mounts im sure, had my drop links and bushes done so cant think what else it could be!
    G
  9. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Sorry to ressurect an old thread but was this the drop links? This is exactly what my car is doing, clunking lunks when the car is lifting of or juddering... Had the front arb and bushes changed and still the same.
  10. s3 ryan
    s3 ryan ryan s3
    26
    same here ive changed the antiroll bushes for power flex ones and ive still got a clunking or sometimes a creak from the front drivers side when going over bumps! its annoying as hell is it worth changing the drop links or could it be somthing else?
  11. Kingston
    Kingston Member
    183
    My does the same first time was pads in Calipers so I fitted my nice new front brake kit and rear up grade.
    Still did it but sounded different mmm
    Had all bushes etc changed at front and everything else checked suspension the lot and still none the litter.
    So next on my list is new suspension and top mounts i'm sure this will sort it but as on my report the ones fitted are fine.
  12. nick-barnes07
    552
    i never got mine sorted so wasn't sure what it was ???
  13. s3 ryan
    s3 ryan ryan s3
    26
    after changing wish bone bushes, top mounts etc i found out by taking the wheel off putting the car on an axle stand then jacked under the hub it was the anti roll bushes still making a noise even tho they are new powerflex ones so i took them off put loads of grease on and it went for 2 weeks without a noise but has started again! im contiplating changing the anti roll bar to an uprated one see if that makes a difference
