Clunking when braking
SinghB7 Jan 7, 2014
  1. SinghB7
    SinghB7 Active Member
    525
    68
    I had my front pads changed in August, when I footbrake there is a clunking coming from the front brakes, like a mettalic clunk.
    Any one else had this problem? What could it be?
    I'm going to strip the front brakes down this weekend and rebuild them see if that makes a difference.
  2. T-800
    T-800 Well-Known Member VCDS Map User
    1,706
    1,369
    Interesting, i started to get this in the wet only recently though, after the brake update on the RS3, after being sat at a junction or lights every now & again I'd hear a clunk/noise as I moved off, stripped the brakes at the weekend but couldn't find anything unusual on inspection.
  3. SinghB7
    525
    68
    I get it in the wet and dry weather. I had a quick visual check and couldn't find nothing. It is when i'm stopping at the lights or braking in normal driving.
  4. ajax1976
    ajax1976 Well-Known Member
    1,279
    656
    I get this too, generally only at lower speeds but I'm not sure if it's only because I just can't hear it at higher speeds. I popped the wheels off and had a quick look, when I rotate the disc back and forth the clunk seems to come from the inner CV or gearbox area and not from the brakes.
    Hopefully you guys can have a quick look at yours and report back.
  5. yendall24
    yendall24 Member
    571
    hi all are you aware that a lot of brake pads are directional . original pads. pagid pads and a host of others have direction arrows stamped into the retaining spring you need to ensure these are pointing in the right direction or you get a clunk when the brakes are applied
  6. schmergal
    schmergal Member
    114
    I've currently the same issue after changing shocks/perch plates/discs and pads
  7. schmergal
    schmergal Member
    114
    Just bought new pad retaining clips so going to fit them see if it helps
  8. trickybusa
    trickybusa Member
    The brake pad carriers can get worn or some pads are slightly smaller which causes a clunking sound which is more noticeable at lower speeds. I have noticed this on motorbikes I have worked on in the past as the sound is more noticeable as you are sat above the calipers.
  9. yendall24
    yendall24 Member
    571
    check out reply no5 before you start worrying about anything else been there done it but its up to you
  10. schmergal
    schmergal Member
    114
    Fitted new brake pad retaining clips, improved clunking sound greatly
