clunk noise when braking
Rudidudi Jun 29, 2014
  1. Rudidudi
    Rudidudi New Member
    as above, there is a single clunk noise coming from what sounds like the passenger side front (?) under braking.
    it doesnt happen all the time...
    ive had the mot guy take a look but he cant see anything 'wrong'.
    any ideas gratefully received!
  2. Garpemo
    Garpemo Member
    33
    Have the same problem.
  3. Rudidudi
    Rudidudi New Member
    are there any things that you've checked and ruled out?
  4. Rudidudi
    Rudidudi New Member
    anyone?
  5. Rudidudi
    Rudidudi New Member
    hmmm....
  6. Garpemo
    Garpemo Member
    33
    I haven't had the time to do that yet. But the sound comes every time I'm braking and acc at slow speed.
  7. overdraft
    overdraft Member
    65
    Sounds like a worn brake pads that are loose in the caliper.
  8. andyt1967
    andyt1967 Member
    30
    or a worn ball joint/bush on a front suspension arm.
  9. TYphoon GB
    TYphoon GB Active Member
    386
    26
    Any breaking at speed wobble....?
    Remove front wheel. Whilst jack up grab lower control arm and shake...if it moves at all replace both and then consider upper arms as well.
    Above 75K miles its probably needed anyway...dont forget new drop links....
  10. adamss24
    adamss24 Well-Known Member
    4,584
    410
    Yeah, most likely a balljoint or cheap pads/worn caliper carrier issue as pointed above. Top front control arms also make that noise when worn as the weight of the car moves the balljoint into it's socket...
  11. Iain-A6
    Iain-A6 Member
    33
    Ball joint, you might not fell anything unless the wishbone is off and you can push the ball joint up and down. If it is completely hanging you will feel it.
  12. Garpemo
    Garpemo Member
    33
    So when it's up try to move the lower link arm?
    I've noticed that I can move the drive shaft front to back ( towards wheel and back) about 1mm does that have to do with this? I think that have to do with my speed wobble at higher speeds.
  13. 6833jon
    6833jon Member
    49
    I have the same on mine, under hard braking or acceleration - Local garage spent 2 hours trying to find the fault last week, found very slight play in a lower rear ball joint, but hardly anything. Had discs and pads changed last weekend and still making noise. Have also noticed if I am turning slightly to the right I am getting a clicking noise but think it might be from the drivers side
  14. TYphoon GB
    386
    26
    Yes it should be firm. If it rocks they need to go. Typically 75k miles. Some small play is normal on the shafts IMHO.
  15. TYphoon GB
    386
    26
    6833jon likes this.
  16. freshtt225
    freshtt225 New Member
    Had same issue. Found my r/f inner cv axle joint badly worn out. Replaced axle and clunk on braking went away.
