closing of drivers window (help)
Vikz Aug 25, 2006
  1. Vikz
    Vikz Member
    92
    my drivers window is struggling close most times. often it would get half way up, slow down then suddenly go back down a little bit.
    i try not to use that window but when i do and have to close it i put my palm against the window and push upwards while my left hand is on the window switch.
    can anyone shed some light on my problem? maybe the motor has gone?
    thanks.
  2. Olly_K
    Olly_K Administrator
    2,678
    sounds like the motor, does it sound any different from the other window motor ? does it sound like its straining ? it's possible the window may of come out of the runners.
  3. madvw
    madvw Active Member
    2,489
    sounds like the age old problem of those crappy plastic runners snapping...
  4. AndyMac
    9,832
    45
    Yes you'll need a new frame/runners for the window, common problem on older A3's. Not expensive though, about £100 fitted IIRC
  5. Vikz
    Vikz Member
    92
    well the motor sounds fine when its going up but then half way up it sounds like it's straining.
    where can get hold of a new frame and runners?
  6. Vikz
    Vikz Member
    92
    i found a set for £75, but i'm still wondering if it's the motor or the frame and runners? can some please advise me coz i don't want to spend £75 on the wrong part.
    thanks
  7. AndyMac
    9,832
    45
    It's far more likely to be the frame as this is a common problem on A3's. If it was the motor then it would be far more likely that it wouldn't work at all.
    I had exactly the same problem with my old A3 1.8T. Drivers window, halfway up would go all the way down. If you hold the up button and manually assist the glass n its travel then no problem.
    What happens is broken runner then allows the window glass to skew slightly on its way up. This puts extra load on the motor which then thinks there's something in the way, so retracts.
    From what you've described I would say it's 99% the frame. I know a handful of people on hear have had the frame go, I haven't heard of a motor even failing let alone getting lazy.
  8. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Yep, mine's doing the same thing at the moment...
    Strangely it's intermittent, it seems far more likely to happen if it's wet. I'm guessing it's the frame too. The door card's coming off on Sunday to investigate...
    Regards,
    Rob.
  9. Vikz
    Vikz Member
    92
    cheers for helpl. will be ordering the frame and runners tomorrow hopefully, found a new set for £60.
    fractionone, let me know whats happening with yours when you take the door card off on sunday.
  10. chrisb
    chrisb Member
    141
  11. Vikz
    Vikz Member
    92
    how come mate? how did you fix yours?
  12. chrisb
    chrisb Member
    141
    Follow the 'click here' (above). The plastic bits that break are about £5.
  13. Vikz
    Vikz Member
    92
    thanks for that, will try and have a look at mine tomorrow.
