climate control unit
gaz4410 Jan 9, 2011
  1. gaz4410
    gaz4410 Member
    57
    help needed
    could anybody tell me how to remove the double din climate control unit
    from my 2007 a3.
  2. sub39h
    sub39h Active Member
    2,502
    put your gear stick into Drive or 4th gear (for more space)
    protect the area with a towel or something
    open the card tray
    stick your hand in the hole and give the trim surround a tug and it should come off.
    with a long thin screwdriver to push the tabs in the top corners of all the buttons, pulling gently to loosen each corner then pull out
    index finger in each corner of the climate unit and give it a sharp tug. you need to use a fair bit of force
    remove wiring
    voila!
    http://www.audi-sport.net/vb/new-a3-s3-sportback-8p-chassis/104649-facelift-centre-console.html
    check post #35
