climate control fan speed
ei2gfb Sep 15, 2013
  1. ei2gfb
    ei2gfb Member
    101
    ive owned my current a4 b6 for approx 1 month and ive noticed the fan speed on the climate control doing weird things, if i change from window to air vent mode the fan speed goes up to nearly full and i have to manually put it back down, then some times it does the opposite if i have it say on 3 and on air vents and switch it to foot vents it will drop to 1 bar, also ive noticed unless both sides are matched in temp it wont let me adjust speed!! and every so often i clance down it seems to do its own this regarding the fan speed and its not set on auto, is my unit acting up i presume it has been for previous owner too as only the fan - and + symbols are worn
  2. hades-
    9,481
    646
    is it on auto ?
  3. ei2gfb
    ei2gfb Member
    101
    no auto is definately off but behaves like it is on auto
  4. hades-
    9,481
    646
    when i move mine from center to screen the fan turns up etc
