Climate Control Codes
gaz71 Jan 20, 2010
  1. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    When I changed my stat recently I used to climate control to see what temp the ecu was reading (code 49).
    Does anyone have a list of what the other codes read, if anything?
  2. aragorn
    18,545
    865
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    It's not 100% that list. I'm guessing the US spec cars were coded slightly differently.
    49 and 51 both seem to be Coolant Temperature, although they are usually a few degrees out until they hit 90. Guess one is the value sent to the cluster and the other to the ECU.
  4. gaz71
    286
    Thanks for the info chaps. Much appreciated :thumbsup:
