Climate Control - Auto Mode Question
B79MJW Apr 8, 2014
  1. B79MJW
    B79MJW Member
    37
    Hi All
    Quick Q...
    Can others please check there systems for me.
    My B6 When on Auto mode with warm engine at 90 degrees it never seems to chuck out cold air to the footwells. so for instance at 18.5 on full auto the wind and face level vents chuck out cold air nothing from footwell vents; however on manual all works as it should and on extremes lowest and highest it does.
    My question is do the footwell vents get bypassed for some reason in auto mode for cold air - as the temp gets higher warm air does comes out on auto just not cool; but flaps must be wiring as manual selects.
    What do yours do?
  2. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    The CC system is monitoring the temperature all over the car and puts it where it needs it for climate control, where manual just blasts it out and calms down when the average temp reaches the requested setting.
    You also have to remember that heat rises so your feet area will be cooler by default.
  3. B79MJW
    B79MJW Member
    37
    Yeah; cheers; Even when it was 18 degrees outside at weekend and climate at 16 i still got no cool air on feet area; but freezing cold to window and face vents... but as you say may be by default as hot air rises. to be honest auto mode HVAC seems to have a mind of its own. No faults on VCDS; its one of those where thou keep wondering is it broke or not - I hate having little issues.
    My main concern was as the feet vents also feed the rear foot vents its not cooling the rear cabin from the rear facing under front seat vents...
    Cheers for reply.
  4. Mike.M
    2,477
    169
    If you have VCDS then you can plug in to diagnostics and check the temp sensors are working ok.
  5. Mike.M
    2,477
    169
    If you have VCDS then you can plug in to diagnostics and check the temp sensors are working ok in the measuring blocks area
  6. madmike01uk
    madmike01uk Member
    430
    21
    mine does the same mate
    B79MJW likes this.
  7. B79MJW
    B79MJW Member
    37
    Does the B6 only have temp sensors in the climate unit and in centre of windscreen?
  8. B79MJW
    B79MJW Member
    37
    Thanks mad mike; Must be something in the Auto HVAC software parameters to cool cabin not footwell.
    The temps in VCDS looked fine and no faults. If it happens in others it must be by design lol.
  9. Mike.M
    2,477
    169
    It's down to the way it monitors the temps as mentioned and where it want to put the air to maintain the temp set. Manual mode is just where you want the air
  10. quattrojames
    14,050
    576
    I think the B6 just has a poor and fairly inefficient HVAC system in honesty.
    ruffrida likes this.
  11. andy.l
    andy.l Member
    224
    20
    ^this
  12. madmike01uk
    madmike01uk Member
    430
    21
    I do like to have my feet cooled lol. I do tend to usual auto though on a warm day though. Might get mine re gassed this year
  13. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,301
    391
    All my cars, including current S4 are always on auto and usually on 21 all the time, all year round.
    The HVAC systems are quite clever although this system is now 14 years old it works very well. A lot of development goes into many different areas of vehicles including the HVAC systems.
    Let it do its thing and keep the cabin and the temp you request.
    If you want cold feet, turn of auto, select lover vents and turn temp down, simple.
    The only button I ever touch is "re-curc" when in traffic for obvious reasons.
