Climate Control / aircon problem Fault Codes
John C Dec 6, 2009
  1. John C
    John C Member
    34
    2003 A6 Avant 2.5 TDI Auto 163 Sport
    Hi I have posted this problem on the Air Con forum & the A6 forum & this is my last port of call!
    My aircon is now off most of the time & occassionally cuts in. It seems to be an electrical problem as when it cuts in I can hear a click.
    I took a fault code reading with my cheap shareware VCDS and this is what I got:
    VCDS Version: Release 805.1
    Data version: 20080823
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
    76 77
    VIN: WAUZZZ4B04N022289
    2 Faults Found
    18062 - Please check DTC Memory of Instrument Cluster
    P1654 - 35-10 - - - Intermittent
    18043 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 35-10 - - - Intermittent
    Readiness: 0 0 X X X
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4B1 910 155 K HW: 01J 927 156 JK
    Component: V30 01J 2.5lTDI RdW 3271
    Revision: 00000008 Serial number: 00000001245312
    Coding: 0000001
    Shop #: WSC 04940 001 00001
    2 Faults Found
    18265 - Load Signal: Error Message from ECU
    P1857 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 736 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 13.0
    Torque: 12.0 Nm
    Temperature: 59.0°C
    T.B. Angle: 0.0°
    Bin. Bits: 0101 0 0
    18161 - Tiptronic Switch (F189): Implausible Signal
    P1753 - 000 - - - Intermittent
    Freeze Frame:
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 3428
    Coding: 06399
    Shop #: WSC 02334
    1 Fault Found
    P1857 - 35-00 - -
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 981 J
    Component: KOMBI+WEGFAHRS. VDO D12
    Coding: 00460
    Shop #: WSC 77824
    WAUZZZ4B04N022289 AUZ7Z0C2442050
    3 Faults Found
    00667 - Ambient Temperature Signal
    30-10 - Open or Short to Plus - Intermittent
    29-10 - Short to Ground - Intermittent
    00562 - Sensor for Oil Level/Temperature (G266)
    27-00 - Implausible Signal
    2 Faults Found
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01134 - Shareware Version. To Decode all DTCs
    76-10 - Please Register/Activate –
    I tried to locate the clicking & took off the panel to access the relays. I couldn't pin it down (as it stopped & the aircon stayed off) but it seemed to be in the area of the relays numbered 370 & 373 - although if their supply was intermittent it would cause them to click anyway...
    It would seem that I have a bad connection some where.....
    I am almost resigned now of having to put this in to Audi - but any help or advice would be appreciated - particularly if it solves the problem!!
    John C
  2. NHN
    29,525
    1,766
    Shareware 805.1, I dont recall such a thing, where did you get it?
  3. John C
    John C Member
    34
    Sorry NHN perhaps I am mistaken..
    I bought it from a well known shopping site on the internet - I assumed it was a shareware version with a third party lead. The software did come on a disc, however, which I thought was easier than dowmloading it.
    John C
  4. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    There was never a shareware version of 805. You are either using an illegal copy of the VCDS/VAG-COM product or you have bought from a legit distributor listed on our distributor page. Incidentally, there are no other legitimate sales channels for our products.
