Clearing up coding for DIS
Steve220 Apr 24, 2013
  1. Steve220
    Steve220 Member
    234
    15
    Hi all,
    Finally got a good deal on a genuine Ross tech cable and have begun by doing a scan, few minor codes came up which were removed, but now where do I go to try and code in DIS? I have a factory fit MFSW and retro fitted cruise already but would like to know where you let the car know I've got the arm on the steering column. Car is a 56 plate A4 B7 avant.
    any pointers or hints to a complete VCDS novice would be greatly appreciated.
    I also heard you can programme remotes on it too? I that true? Would be great as one of my remotes stopped working after a few days then after the battery change it wouldn't sync.
  2. hades-
    9,480
    646
    to sync the remote just put it in ignition turn on not start
    then press lock then unlock
    take out and retry
    sorted
  3. hades-
    9,480
    646
    Coding
    • 0?xxx: Steering Wheel
      • 0 = Standard (without Multifunction)
      • 1 = 3-Spoke Steering Wheel (Sport Steering Wheel)
      • 2 = Multifunction Steering Wheel with Radio Control
      • 3 = Multifunction Steering Wheel with Radio/Telephone Control
      • 4 = Multifunction Steering Wheel with Radio/Telephone/Voice Control
      • 5 = Multifunction Steering Wheel with Radio/Voice Control
    • 0x?xx: Options
      • +1 = Tiptronic
    • 0xx?x: Board Computer & Cruise Control
      • 0 = Board Computer & Cruise Control not installed
      • 1 = Board Computer installed
      • 2 = Cruise Control installed
      • 4 = Board Computer & Cruise Control installed
    • 0xxx?: Rear Wiper (Chassis)
      • 1 = Rear Wiper not installed (Sedan/Cabriolet)
      • 2 = Rear Wiper installed (Avant)
  4. Steve220
    Steve220 Member
    234
    15
    yeh tried that at the time. No response.
  5. Steve220
    Steve220 Member
    234
    15
    so I take it the code i need to put in is 04042??
  6. Steve220
    Steve220 Member
    234
    15
    Guys,
    My original code in 16 was 02022, which i changed to 02042. I cleared all the codes before hand and then clicked 'Go!', closed it down, waited a while then started the car up, the DIS still doesn't work. Any ideas? Do I have to log on? If so what is the code?
  7. Steve220
    Steve220 Member
    234
    15
    Sorted it, apparently had to code the instruments too.
  8. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    Nice one Steve. VCDS is a powerful tool mate so be careful and always remember to note down old codes before you change them JUST in case.
  9. Steve220
    Steve220 Member
    234
    15
    im slowly getting the hang of it. I resynchronised my other remote yesterday too :) happy chap.
  10. s3reptdi
    s3reptdi Member
    179
    How did you do it?
  11. Steve220
    Steve220 Member
    234
    15
    which bit?
  12. s3reptdi
    s3reptdi Member
    179
    Re sync your remote?
  13. Brodster
    3,548
    882
    Steve....have sent you a FB message mate about the DIS recode.
