Clearing codes
martyboy Nov 22, 2009
  1. martyboy
    martyboy Member
    532
    20
    hi, i am a fairly new owner /user of vag-com, so at the risk of sounding silly, here goes!
    how do you clear your fault codes, is it just as simple as pressing the button, 'clear codes'?
    its just that after hitting this button, all the codes are still there without having even started the car up let alone driving it!
    dont be to harsh please,
    cheers!
  2. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    Clicking that button worked for me...
  3. NHN
    29,563
    1,779
    When you say new owner, what version?
  4. martyboy
    martyboy Member
    532
    20
    micro-can
  5. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    Yes, all you need to do is clear the codes in the controller. Now, if they immediately reappear, then you have a real problem in the car. The controller is setting them immediately again. That means nothing has been fixed and so the fault cannot be cleared. Not all faults require the engine to run.
    If you really want help, you should post an autoscan here for others to see and comment on.
  6. martyboy
    martyboy Member
    532
    20
    VCDS Version: Release 805.4
    Data version: 20090602
    Friday,19,June,2009,08:33:51:15629
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    VIN: WAUZZZ8P65A103943 Mileage: 155740km/96772miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door,Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC 0000SG 6337
    Revision: 12345678 Serial number: AUX7Z0DDFN90RI
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0023174
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
    Component: KlimavollautomatH14 0180
    Revision: 133310 Serial number: 8P0820043H
    Shop #: WSC 06314 000 00000
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 77
    Reset counter: 41
    Mileage: 152269 km
    Time Indication: 0
    Date: 2009.03.30
    Time: 07:31:34
    Freeze Frame:
    Temperature: 7.5°C
    Voltage: 14.40 V
    RPM: 2500 /min
    Load: 0.0 %
    Load: 9.0 %
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001338013
    Coding: A1884F02B214100000160000160000000000FE0F5C
    Shop #: WSC 06314 000 08192
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    3 Faults Found:
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    009 - Open or Short to Ground - Intermittent
    01800 - Light Switch (E1)
    008 - Implausible Signal - Intermittent
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 3230
    Revision: 91H10323 Serial number: 00362001GZ5P
    Coding: 0034622
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
    Component: Lenksäulenmodul 021 0050
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
    Component: KOMBIINSTR. VDO H73 0300
    Revision: D04 Serial number: 224DDD04003287
    Coding: 0004403
    Shop #: WSC 00107 210 64237
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104B240929
    Coding: 3D3F0B42072103
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 155653 km
    Time Indication: 0
    Date: 2009.06.16
    Time: 16:41:19
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D04 Serial number: AUX7Z0DDFN90RI
    Shop #: WSC 00000 000 00000
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000048
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.8 1502
    1 Fault Found:
    Freeze Frame:
    Mileage: 5640 km
    Temperature: 22.0°C
    Voltage: 12.00 V
    Voltage: 11.80 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 188000186D080D0D489FC63000
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH03 0180
    Revision: 00002 Serial number: 10000001185408
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000048
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H51 0100
    Revision: 01S Serial number: AUZ2Z3D1804907
    Coding: 0001001
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 56
    Mileage: 155306 km
    Time Indication: 0
    Date: 2009.06.07
    Time: 16:13:48
    Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 B
    Component: Tuer-SG H10 0010
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 B
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    End ---------------------------------------------------------------------
  7. pns2007
    pns2007 Moonstone Grey VCDS Map User
    689
    64
  8. martyboy
    martyboy Member
    532
    20
    the leaving/coming home lights mod is all!
  9. NHN
    29,563
    1,779
    Update your version Marty as you're running 805 when we're now on 908.1 mate.
