Clear Indicator Bulbs
quattrojames Mar 15, 2009
  1. quattrojames
    14,050
    578
    It's the little things :o.k:
    Bought a set of Philips Silver Vision from Powerbulbs and fitted them today:
    Before and after pictures below:
  2. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    112
    its the first thing i did, makes hell of a difference, really tidys the front up.
  3. James88
    James88 Member
    44
    that does look much better
  4. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Did that to my B6 S4s and to my wifes' Skoda - just wish it was as easy to do on the B7.
    It looks so much better with the "fried egg" look gone.
  5. 1wheelonly
    2,385
    112
    petrol,
    is it the lens itself thats orange on the b7 then?
  6. quattrojames
    14,050
    578
    I am not 100% sure, but I think on the B7 it's the later models that come with the clear corner headlights, check out the below pics:
    (Courtesy of Ultramodz :hi:)
    [​IMG][/quote]
  7. MattS5
    MattS5 Active Member
    619
    60
    I've wanted to do this for awhile, but it just looks so bl00dy difficult to get in there to change them. Any tips to make it easy(er)?
  8. quattrojames
    14,050
    578
    On a B6? Just take the lights out mate, if it took me 10 minutes a side I will be surprised! You don't even need to unplug the lights, just pull them forward enough to get to the indicator bulb at the side. Hope the following helps:
  9. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    and anybody wanting to swipe and print quattrojames pics below, don't make the mistake that I did and make sure you get all of 'em:
    "http://www.audifans.net/modules/gallery/albums/album51/A4_headlamp.sized.jpg"
    "http://www.audifans.net/modules/gallery/albums/album51/A4_headlamp2.sized.jpg"
    "http://www.audifans.net/modules/gallery/albums/album51/A4_headlamp3.sized.jpg"
    "http://www.audifans.net/modules/gallery/albums/album51/A4_headlamp4.sized.jpg"
    "http://www.audifans.net/modules/gallery/albums/album51/A4_headlamp6.sized.jpg"
    And correct, there's no #5 - that's taken out of the webpage source code!
    edit: made the URL's active, so the really lazy can just netXfer/FlashGot the links ;)
  10. PetrolDave
    1,559
    85
    Yes, until a running change was introduced sometime in late '07 (ETKA gives the VIN number when the change happened) the B7 headlights had clear indicator bulbs and a nasty piece of orange plastic inside them, after that they used orange bulbs which can easily be changed to e.g. Philips Silver Vision ones.
    Converting the older headlights means putting them in an oven to soften the glue, prising the two parts apart and levering out the piece of orange plastic, then hoping the two parts seal properly when you put them back together again.
  11. Broken Byzan
    13,237
    465
    Cant the plastic be broken up in place/through the bulb hole? Like the B5 US clear corner mod?
    Basicly they drill and break the part up and remove it though the bulb hole with snipe nose pliers etc
  12. PetrolDave
    1,559
    85
    Nope, it's been tried....
  13. Tendaimwari
    Tendaimwari Member
    124
  14. quattrojames
    14,050
    578
  15. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    yeah stop being tight!!haha Change the bulbs..
  16. Toxic
    Toxic Member
    54
    So does the same apply to the UK A4 Cab for changing indicator bulbs?
