cleaning the chrome window trim
imported_kris_tdi Apr 5, 2005
  1. as above it looks foggy, tried a bit of polish on it but it didnt do anything, any suggestions?
  2. dickys3
    2,954
    What about solvol autosol available from Halfords? Or any chrome cleaner?
  3. scoTTy
    scoTTy Active Member
    1,962
    I wouldn't go for metal polish. Isn't the chrome plastic coated?
  4. yeah i think it is coated plastic, why i was wary of using even paint polish on it.
  5. Mcgough
    Mcgough Member
    846
    Listen guys i swear by autoglym, I used to have a set off chrome wheels and used alloy wheel seal, its in a spray can and you can use it on your allos if you dont like it, it sprays a white mist which you just rub once to finish the job!!
  6. Lowride
    Lowride Member
    137
    Definetly put some polish on mate, if it does`nt get u the right results use some polish with a bit of cut in it. It would be very hard to damage the chrome trim using polish
  7. dreddg
    dreddg Member
    81
    Hi all
    I am also experiencing the same problem with my roof rails...I have tried autosol and car polish but no joy
    I was thinking about using wire wool....what do you reckon???? /ubbthreads/images/graemlins/noidea.gif
  8. madvw
    madvw Active Member
    2,489
    dont know if its a plastic coating or a laquer finish, but wire wool is definately not the way to go.
    if it is a laquer, you could try a tcut for metallic cars.
  9. dreddg
    dreddg Member
    81
    [ QUOTE ]
    [/ QUOTE ]
    Hi Mad
    Thanks for the info...i will give it a go, i was also thinking of giving it a go with a polish mop, with the high speed it may clear the fogging....will post my results on here if succesful. /ubbthreads/images/graemlins/book.gif
